When I want to upgrade the backtrack linux to ubuntu 14.04 the following errror occurs:
(Reading database ... 218798 files and directories currently installed.)
Preparing to replace hostname 3.03ubuntu1 (using .../hostname_3.15ubuntu1_amd64.deb) ...
Unpacking replacement hostname ...
dpkg-deb: file `/var/cache/apt/archives/hostname_3.15ubuntu1_amd64.deb' contains ununderstood data member data.tar.xz     , giving up
dpkg: error processing /var/cache/apt/archives/hostname_3.15ubuntu1_amd64.deb (--unpack):
 subprocess dpkg-deb --fsys-tarfile returned error exit status 2
How can I fix it? Note: I copied the ubuntu repos to bactrack
MLSC
  • 310
You can't upgrade Kali(backtracks' new name) to Ubuntu. Kali is Debian Testing based.
Ege
  • 59
