I recently installed a fresh copy of Ubuntu server 14.04. The install was fine. But after the install the problems begin. To be sure I have al the recent updates I typed sudo apt-get update. The result I get is no update only errors. It somehow can't fetch any of the stated links. So I tought maybe the links are wrong but that ain't the problem. I changed the links and it still doesn't work.
So I tought maybe there is a problem with my internet connection (I use WIFI). So I googled around and found this post: Ubuntu 14.04 Server - WiFi WPA2 Personal. After I tried that the following results: iwconfig:
lo no wireless extensions
wlan0 IEE 802.11ng ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=20 dBm
Retry long limit:7 RTS thr:off Fragnebt thr:off
Power Management:on
ifconfig:
lo all the normal values
In /etc/network/interfaces I have the following:
auto lo
iface lo inet loopback
auto wlan0
iface wlan0 inet static
address 192.168.000.15 # (000) is something else
netmask 255.255.255.0
gateway 192.168.000.1 ipconfig from a windows pc gives (so not from the router itself)
wpa-ssid the network name
wpa-psk the network password
dns-nameservers 8.8.8.8 8.8.4.4
Also ping doesn't give me anything to work with. If I ping the ip adress I entered in interfaces it will receive the packages. If I ping google I get host unknow
During installation I installed the following packages:
  • ubuntu basic server;
  • OpenSSH;
  • Apache server;
  • mail server;
  • samba file server
Added: When I dosudo ifdown wlan0 && sudo ifup -v wlan0 all things seems to be normal except for 2 things: on the 1st line: ifdown: interface wlan0 not configured and on the last line: Failed to bring up wlan0
Update After a few reboots iwconfig now returns:
wlan0 IEE 802.11ng ESSID:"my network name"
Mode:Managed Frequency:2.427 GHz Access Point: blabla
Bit rate=54Mb/s Tx-Power=20 dBm
Power Management:on
and so on
So I hope everything is now working
If I need to add more information please let me know. I hope someone can fix my problem with internet connection. Thanks in advance.
Please amend your interfaces file to correct:
The s at the end is crucial. Restart the interface:
The -v for verbose will produce some messages indicating probable success or errors. Test:
ping -c3 www.google.com
By the way, you are behind a router and you have a private IP address. Your 192.168.x.y or 10.0.1.x address gives away nothing personally identifiable, but could help us diagnose your issue.
chili555
  • 61,330
I think there is problem with your gateway ,it should be same as of printed on your router. If that's not the problem,
  1. Comment out static settings
  2. Use dhcp again
  3. Restart with
    sudo reboot
  4. ping www.google.com
  5. If works use ifconfig to see your correct settings, and use them again in your configuration file.
