-1
Bus 003 Device 004: ID 05c6:1000 Qualcomm, Inc. Mass Storage Device
is shown, but it says modem not detected.
My modem:
  • Network type: CDMA 1X-EVDO , USB2.0 Connector
  • Quad-band: CDMA 800/1900MHZ
David Foerster
  • 36,890
  • 56
  • 97
  • 151
It is detecting it as mass storage and the driver is not loaded.
For Your device issue following commands: first find the id of your device issuing lsusb command in terminal
lsusb
If your output looks like this
Then use modprobe to change from USB mass storage to modem or i.e provide driver with following command
sudo modprobe usbserial vendor=0x05c6 product=0x1000
After this your modem will be detected, according to your desktop environment use your networkmanager to connect,
To check the status of your device you can issue following command
dmesg
There will be GSM modem instead of mass storage....
guntbert
  • 13,475
Anup
  • 26
This works for me on Ubuntu 14.04:
  1. Download and unzip config-pack to /etc/usb_modeswitch.d/
  2. Reboot computer.
My modem is active after about one minute.
Original post in foreign language.
Eliah Kagan
  • 119,640
  1. eject the CD-ROM as it automatically got attached
    eject sr1
  2. modeprobe for kernel provides driver for modem
    sudo modprobe usbserial vendor=0x05c6 product=0×6000
  3. WVDIAL utility to connect using our modem, configure it by editing the /etc/wvdial.conf with content as below (make sure to change your username and password).
    [Dialer Defaults]
    Init1 = ATZ
    Init2 = ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0
    Modem Type = Analog Modem
    Baud = 460800
    New PPPD = yes
    Modem = /dev/ttyUSB0
    ISDN = 0
    Phone = #777
    Password = YOUR_USERNAME
    Username = YOUR_PASSWORD
    stupid mode = 1
  4. Do step 2, 3 in 1-2 second interval, or Modem will get passive.
Reference
techraf
  • 3,316
-2
Use EVDO CDMA Modem in Ubuntu (Orginal Post)
Use EVDO CDMA Modem in Ubuntu (Supporting Post)
Guest
