My machine seems to wake up from suspend by itself, at irregular intervals. Causing the power to die out, and machine turn off.
It is quite the annoyance, when the machine is in my case and it wakes up. And quite unhealthy as well, I would persume. It also wakes in the middle of the night, which is why I have to remember to hook on the power supply, or else i have a flat battery in the morning.
The machine is a Lenovo X1 Carbon with Ubuntu 14.04. I use it with a OneLink dock at work, but just with the power supply and a displayport monitor at home.
Now here is what I have done so far. I have had it suspended, and after about 3 hours, it woke up, as the logs below testify to:
from pm_suspend:
Running hook /etc/pm/sleep.d/novatel_3g_suspend suspend suspend:
/etc/pm/sleep.d/novatel_3g_suspend suspend suspend: success.
Thu Jul 24 17:18:26 CEST 2014: performing suspend
Thu Jul 24 20:17:04 CEST 2014: Awake.
Thu Jul 24 20:17:04 CEST 2014: Running hooks for resume
Running hook /etc/pm/sleep.d/novatel_3g_suspend resume suspend:
/etc/pm/sleep.d/novatel_3g_suspend resume suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/99video resume suspend:
/usr/lib/pm-utils/sleep.d/99video resume suspend: success.
from syslog:
$ grep -B 5 "20:17:0" /var/log/syslog.1
Jul 24 17:18:25 lobners-biq dbus[548]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jul 24 17:18:25 lobners-biq dbus[548]: [system] Activating service name='org.freedesktop.systemd1' (using servicehelper)
Jul 24 17:18:25 lobners-biq dbus[548]: [system] Successfully activated service 'org.freedesktop.systemd1'
Jul 24 17:18:25 lobners-biq anacron[11164]: Anacron 2.3 started on 2014-07-24
Jul 24 17:18:25 lobners-biq anacron[11164]: Normal exit (0 jobs run)
Jul 24 20:17:04 lobners-biq kernel: [ 7351.710460] PM: Syncing filesystems ... done.
Jul 24 20:17:04 lobners-biq kernel: [ 7351.720943] PM: Preparing system for mem sleep
Jul 24 20:17:04 lobners-biq kernel: [ 7351.721161] Freezing user space processes ... (elapsed 0.002 seconds) done.
Jul 24 20:17:04 lobners-biq kernel: [ 7351.723370] Freezing remaining freezable tasks ... (elapsed 0.047 seconds) done.
Jul 24 20:17:04 lobners-biq kernel: [ 7351.770482] PM: Entering mem sleep
Jul 24 20:17:04 lobners-biq kernel: [ 7351.770544] Suspending console(s) (use no_console_suspend to debug)
Jul 24 20:17:04 lobners-biq kernel: [ 7351.897854] sd 0:0:0:0: [sda] Synchronizing SCSI cache
Jul 24 20:17:04 lobners-biq kernel: [ 7351.901194] sd 0:0:0:0: [sda] Stopping disk
Jul 24 20:17:04 lobners-biq kernel: [ 7352.149522] PM: suspend of devices complete after 378.694 msecs
Jul 24 20:17:04 lobners-biq kernel: [ 7352.165538] PM: late suspend of devices complete after 16.005 msecs
Jul 24 20:17:04 lobners-biq kernel: [ 7352.181723] ehci-pci 0000:00:1d.0: System wakeup enabled by ACPI
Jul 24 20:17:04 lobners-biq kernel: [ 7352.197584] e1000e 0000:00:19.0: System wakeup enabled by ACPI
Jul 24 20:17:04 lobners-biq kernel: [ 7352.229549] xhci_hcd 0000:00:14.0: System wakeup enabled by ACPI
Jul 24 20:17:04 lobners-biq kernel: [ 7352.245757] PM: noirq suspend of devices complete after 80.176 msecs
Jul 24 20:17:04 lobners-biq kernel: [ 7352.246048] ACPI: Preparing to enter system sleep state S3
Jul 24 20:17:04 lobners-biq kernel: [ 7352.247624] PM: Saving platform NVS memory
Jul 24 20:17:04 lobners-biq kernel: [ 7352.248416] Disabling non-boot CPUs ...
Jul 24 20:17:04 lobners-biq kernel: [ 7352.249937] smpboot: CPU 1 is now offline
Jul 24 20:17:04 lobners-biq kernel: [ 7352.353589] smpboot: CPU 2 is now offline
Jul 24 20:17:04 lobners-biq kernel: [ 7352.457641] smpboot: CPU 3 is now offline
(clipped)
I know that I can disable which hardware is allowed to wake it, but I do not know which hardware is the culprit. I disabled the LID (using acpitool -W 1), but it still woke up.
$ acpitool -w
Device S-state Status Sysfs node
1. LID S4 *disabled
2. SLPB S3 *enabled
3. IGBE S4 *disabled pci:0000:00:19.0
4. EXP2 S4 *disabled pci:0000:00:1c.1
5. XHCI S3 *enabled pci:0000:00:14.0
6. EHC1 S3 *enabled pci:0000:00:1d.0
I then disabled the two USB ones (5 & 6) but still it wakes up.
$ acpitool -w
1. LID S4 *disabled
2. SLPB S3 *enabled
5. XHCI S3 *disabled pci:0000:00:14.0
6. EHC1 S3 *disabled pci:0000:00:1d.0
Again:
from pm_suspend:
Thu Jul 24 23:11:59 CEST 2014: performing suspend
Fri Jul 25 01:58:01 CEST 2014: Awake.
Fri Jul 25 01:58:01 CEST 2014: Running hooks for resume
from syslog:
$ grep -B 5 "01:58:" /var/log/syslog.1
Jul 24 23:11:58 lobners-biq dbus[548]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jul 24 23:11:58 lobners-biq dbus[548]: [system] Activating service name='org.freedesktop.systemd1' (using servicehelper)
Jul 24 23:11:58 lobners-biq dbus[548]: [system] Successfully activated service 'org.freedesktop.systemd1'
Jul 24 23:11:58 lobners-biq anacron[16204]: Anacron 2.3 started on 2014-07-24
Jul 24 23:11:58 lobners-biq anacron[16204]: Normal exit (0 jobs run)
Jul 25 01:58:01 lobners-biq kernel: [17846.114837] PM: Syncing filesystems ... done.
Jul 25 01:58:01 lobners-biq kernel: [17846.147640] PM: Preparing system for mem sleep
Jul 25 01:58:01 lobners-biq kernel: [17846.147832] Freezing user space processes ... (elapsed 0.002 seconds) done.
Jul 25 01:58:01 lobners-biq kernel: [17846.149916] Freezing remaining freezable tasks ... (elapsed 0.090 seconds) done.
Jul 25 01:58:01 lobners-biq kernel: [17846.240249] PM: Entering mem sleep
Jul 25 01:58:01 lobners-biq kernel: [17846.240309] Suspending console(s) (use no_console_suspend to debug)
Jul 25 01:58:01 lobners-biq kernel: [17846.370439] sd 0:0:0:0: [sda] Synchronizing SCSI cache
Jul 25 01:58:01 lobners-biq kernel: [17846.373919] sd 0:0:0:0: [sda] Stopping disk
Jul 25 01:58:01 lobners-biq kernel: [17846.618053] PM: suspend of devices complete after 377.454 msecs
Jul 25 01:58:01 lobners-biq kernel: [17846.634086] PM: late suspend of devices complete after 16.022 msecs
Jul 25 01:58:01 lobners-biq kernel: [17846.666119] e1000e 0000:00:19.0: System wakeup enabled by ACPI
Jul 25 01:58:01 lobners-biq kernel: [17846.714324] PM: noirq suspend of devices complete after 80.194 msecs
Jul 25 01:58:01 lobners-biq kernel: [17846.714615] ACPI: Preparing to enter system sleep state S3
Jul 25 01:58:01 lobners-biq kernel: [17846.716223] PM: Saving platform NVS memory
Jul 25 01:58:01 lobners-biq kernel: [17846.717020] Disabling non-boot CPUs ...
Jul 25 01:58:01 lobners-biq kernel: [17846.718527] smpboot: CPU 1 is now offline
Jul 25 01:58:01 lobners-biq kernel: [17846.822120] smpboot: CPU 2 is now offline
Jul 25 01:58:01 lobners-biq kernel: [17846.822517] Broke affinity for irq 23
Jul 25 01:58:01 lobners-biq kernel: [17846.822519] Broke affinity for irq 57
Jul 25 01:58:01 lobners-biq kernel: [17846.926171] smpboot: CPU 3 is now offline
Jul 25 01:58:01 lobners-biq kernel: [17846.927621] ACPI: Low-level resume complete
Jul 25 01:58:01 lobners-biq kernel: [17846.927675] PM: Restoring platform NVS memory
Jul 25 01:58:01 lobners-biq kernel: [17846.928186] Enabling non-boot CPUs ...
Jul 25 01:58:01 lobners-biq kernel: [17846.928215] x86: Booting SMP configuration:
Jul 25 01:58:01 lobners-biq kernel: [17846.928216] smpboot: Booting Node 0 Processor 1 APIC 0x1
Jul 25 01:58:01 lobners-biq kernel: [17846.942510] CPU1 is up
Jul 25 01:58:01 lobners-biq kernel: [17846.942524] smpboot: Booting Node 0 Processor 2 APIC 0x2
Jul 25 01:58:01 lobners-biq kernel: [17846.956793] CPU2 is up
Jul 25 01:58:01 lobners-biq kernel: [17846.956806] smpboot: Booting Node 0 Processor 3 APIC 0x3
Jul 25 01:58:01 lobners-biq kernel: [17846.971073] CPU3 is up
Jul 25 01:58:01 lobners-biq kernel: [17846.974855] ACPI: Waking up from system sleep state S3
(clipped)
While the pm_suspend logs are similar, there is some discrepancy in the syslog files. I don't know what to make of that?
Does anybody have an idea as to what this might be??
NOTE: the similar question "Ubuntu 12.04 - Wakes from Suspend by itself" is NOT a duplicate. It does not seem that the scripts in the answer has any effect, and my problem is also not with it failing to suspend or wake. It fails to stay in suspend. Which is also what the question sort of is about, but the wake-on-lan option in ethtool is also 'd' in my case.
