To turn on/off between the 2 cards, I used acpi_call and bumblebee as in this article: https://launchpad.net/~hybrid-graphics-linux
It works. However, from the first time I install a fresh Ubuntu and also now, I can't enable desktop visual effects. Even if turning on Nvidia card.
My laptop is Asus K53SV, core i7 Sandy Bridge. Don't know what the problem is?
Update: Intel integrated card info using lshw command:
*-display
         description: VGA compatible controller
         product: Sandy Bridge Integrated Graphics Controller
         vendor: Intel Corporation
         physical id: 2
         bus info: pci@0000:00:02.0
         version: 09
         width: 64 bits
         clock: 33MHz
         capabilities: vga_controller bus_master cap_list rom
         configuration: driver=i915 latency=0
         resources: irq:45 memory:dd400000-dd7fffff memory:b0000000-bfffffff ioport:e000(size=64)
Bruno Pereira
  • 74,715
Duc Tran
  • 335
I had similar problem on ubuntu 11.04 with optimus. After fresh install there was nvidia driver (or nouveau - I dont rememeber) set in xorg.conf, but you cant directly use nvidia with optimus. Try to delete or rename the file /etc/X11/xorg.conf, or try to change the settings to use intel card. Bumblebee has its own config file for nvidia, so dont worry
gaspo
  • 96
By default Ubuntu see that there is NVIDIA card, but no driver for it, so Unity is disabled. When I tried installing driver for NVIDIA, got black screen. Restarted in fail-safe graphics mode, removed driver, configured xorg.conf for Intel and now Unity works. Still haven't tried Bumblebee.
Tower_9
(My solution to your problem is at the end of this post)
I have got a sony vaio Z790 laptop, with an onboard Intel graphics card an a dedicated GeForce 9300M gs Nvidia card. I am working on Ubuntu Oneiric 11.10. When using windows I can only switch between them using a hardware switch, so I assume that my model does not support the Nvidia "Optimus" technology.
I still haven't managed to work with the Nvidia card and I am stuck with the integrated from intel. When I install the Nvidia drivers (either from their website or using jockey) and restart X, I get a black screen. I have fiddled a bit with the xorg.cong file (adding various options such as a custom monitor EDID (CustomEDID option), specifying explicitly where the Nvidia card is connected (using the BusID option) and others, but the furthest I have got is to get a small white window on the top left of a totally black screen.
Back to your problem: From what I have experienced, my understanding is that once you install an nvidia driver your whole OpenGL configuration is messed-up. Even if you uninstall the drivers afterwards using nvidia-uninstall, still you wont get the 3D unity interface when you restart.
I have written the following little script which combines things I have read in varius forums, which always restores the intel configuration after an unsuccessful attempt to install some kind of driver to get my nVidia card working:
(note the this might mess-up your bumblebee configuration - I haven't looked a lot into bumblebee yet)
sudo apt-get purge nvidia*
sudo apt-get install --reinstall xserver-xorg-video-intel  libgl1-mesa-glx:amd64 libgl1-mesa-glx:i386 libgl1-mesa-dri:amd64 libgl1-mesa-dri:i386 xserver-xorg-core
sudo dpkg-reconfigure xserver-xorg
sudo update-alternatives --remove gl_conf /usr/lib/nvidia-current/ld.so.conf
sudo rm /etc/X11/xorg.conf
sudo stop lightdm
sudo start lightdm
Instead of typing the commands one by one, you can 1. copy this script to a new file 2. save it as you wish (e.g. "fix.run") 3. open a terminal, navigate to the directory where your script is 4. execute the command "sh fix.run" (replace fix.run with your filename)
(Note that I have no idea if the last 2 commands will work in earlier versions of ubuntu - I am new to linux. In case they don't, just find out how to restart your X server, or try hitting ctrl+alt+backspace or ctrl+print screen+k). Hopefully you will fall back on your intel configuration with the nouveau drivers and after a few seconds you will be back on unity 3D.
Hope this helps, Nikos
