I am using x11rdp with xrdp v0.6.0 in ubuntu 12.04
The problem that when I connect remotely from home to office my session is stuck!
When I get back to work I can't open applications that are already run in the x11rdp session. e.g. Firefox, empathy...
I have to close them then I can open the needed app again.
I know I can pkill -u user but it seems non-professional
I tried sudo service xrdp restart (or stop then start). It doesn't close current sessions.
Is there is any xrdp session manager like in windows server or can I kill only my user's session?
kamil
  • 7,397
Using the command below:
ps u -u "$USER" | awk '/xrdp/ && ! /awk / {system("kill "$2)}'
  • Replace $USER with another user name if the process is running with a different user than you
  • Replace xrdp with your process name
A.B.
  • 92,125
To close your own session(s),
pkill -HUP xrdp
should be good enough. (It works for me.)
ps aux | grep <user> | grep -i x11rdp
will give you the process id in the second column of the line that's not your grep.
You can then
kill -9 <pid>
-1
To list all the rdp sessions with theire respective pid and port numbers:
{ echo "user pid Xdisplay port"; { ps -ef | \
  awk '/Xvnc :[[:digit:]]+/ {print $1,$2,$9}' | while read tu tpid tvnc; \
  do sudo netstat -tlpn | awk -v "tpid=${tpid}" '$0 ~ tpid {print $4;}' | \
  sed -r -e 's/^.*://;' -e "s/^/${tu} ${tpid} ${tvnc} /;" ; done ; } | \
  sort -k3 ; } | column -c4 -t
you can then kill the specific process id (pid):
$ kill -9 <pid>
abu_bua
  • 11,313
