I'm really new to Linux so I apologize in advance for my generalized ignorance on the subject. (I apologize for my English as well) Recently, after Microsoft stopped to provide support to Windows XP, I decided to install LXLE 12.04 32-bit on an old PC I own.
The installation went well and I can use LXLE through the Live CD without any issues (actually at this very moment I'm writing this post from there). The problem arises when I take out the CD and try to boot from the hard drive - then the screen turns black and I get the following message - "Attention - Out of range - H: 92.6 KHZ - V: 58.3 HZ" I looked for solutions online and it seems it's a screen resolution problem, but I can't really see what to do to fix it. I tried reinstalling but that doesn't help either.
On the back of my monitor there are some indications which I think are related to the issue and that I'm copying here: "Power rating: 100-240V - 50/60 HZ 1.5 A" If more information about the computer is needed in order to help me, please tell me so and I'll add it to the post.
Thanks in advance!!
ssinyam
  • 33
First of all, are you using a linux operating system with LXDE desktop on its own or are you using Lubuntu, which is a version of Ubuntu with LXDE desktop? The latest seems a more simpler choice for users who come from Windows, but Lubuntu 14.04.1 has already been released.
I am not an expert, but if the method in the link of the first reply did not work, it might be a screen resolution problem and the most voted answer in this topic might solve the problem: How do I safely change grub2 screen resolution?
You should be aware that a system called Grub is loaded before Linux and then you can prevent Linux from being loaded in order to change its loading way.
And you can also open a text terminal when Linux has finished loading. In a terminal you can run command to change the screen resolution and edit files to vary the default screen resolution. Press and hold Ctrl+Alt+F1 to open to a text terminal and Ctrl+Alt+F7 to go back to the usual graphic terminal.
That most voted answer describe how to change the screen resolution before Linux starts being loaded and a reply by @user01 to this most voted tells how to do the same after Linux has finished loading.
Anyway I do not know if this can be a screen resolution problem, but I wanted to note the information about terminals and grub and suggest this other option.
You can download Lubuntu 14.04.1 from www.lubuntu.net.
Goodbye
