I want to use my Apple long aluminium keyboard with swapped Command and Ctrl keys. How is this done step by step on Trusty Tahr (14.04) using xkb?
Note: This solution doesn't work for me as xkb replaced xmodmap in 13.04 or even earlier.
Artur Meinild
  • 31,035
This answer is mostly based on the answer given here. The reason I ask and answer this question again is the final step, which was not fully described. For further reading about xkb look here, here, and here.
  1. Create a file in /usr/share/X11/xkb/symbols (could also be in /etc/X11/xkb/symbols) called altwin2 and containing the following mapping:
    // Control is SWAPPED with Win-keys
    partial modifier_keys
    xkb_symbols "cmd_n_ctrl" {
        key <LWIN> {        [       Control_L               ]       };
        key <RWIN> {        [       Control_R               ]       };
        key <LCTL> {       [       Super_L         ]       };
        modifier_map Control { <LWIN>, <RWIN> };
        modifier_map Mod4 { <LCTL> };
  2. Insert the following line under the option = symbols section in /usr/share/X11/xkb/rules/evdev (disregard the warning on the first line):
    altwin2:cmd_n_ctrl               =       +altwin2(cmd_n_ctrl)
  3. Add the new option to /usr/share/X11/xkb/rules/evdev.lst under the section option:
    altwin2:cmd_n_ctrl    Win swapped with Ctrl
  4. If you don't know where your keyboard configuration file is, you can edit it using dconf-editor, adding "altwin2:cmd_n_ctrl" in xkb-options under org::gnome::desktop::input-sources as shown here. If you know where your configuration file is, you should include the new option in the XkbOptions field as shown below:
    Section "InputClass"
            Identifier "keyboard-layout"
            Driver "evdev"
            MatchIsKeyboard "yes"
            Option "XkbLayout" "us, ru, ca, fr"
            Option "XkbOptions" "altwin2:cmd_n_ctrl"
    EndSection
  5. Either reboot or restart lightdm to update the changes:
    sudo restart lightdm
NOTE: if any changes are made directly in the layout files, i.e. not using options, the cached files in /var/lib/xkb/ need to be deleted as indicated here.
In 16.04, here's the way I finally got this to work. Xmodmap doesn't work universally in all apps, gnome tweak tool lacked the function, dconf editing a custom altwin2 key swap (like the main answer here) failed, so I was tearing my hair out until I combined several answers into this complete, simple, and elegant solution:
gksudo gedit /usr/share/X11/xkb/symbols/pc
change it to:
default  partial alphanumeric_keys modifier_keys
xkb_symbols "pc105" {
key <ESC>  {    [ Escape        ]   };
// The extra key on many European keyboards:
key <LSGT> {    [ less, greater, bar, brokenbar ] };
// The following keys are common to all layouts.
key <BKSL> {    [ backslash,    bar ]   };
key <SPCE> {    [    space      ]   };
include "srvr_ctrl(fkey2vt)"
include "pc(editing)"
include "keypad(x11)"
key <BKSP> {    [ BackSpace, BackSpace  ]   };
key  <TAB> {    [ Tab,  ISO_Left_Tab    ]   };
key <RTRN> {    [ Return        ]   };
key <CAPS> {    [ Caps_Lock     ]   };
key <NMLK> {    [ Num_Lock      ]   };
key <LFSH> {    [ Shift_L       ]   };
key <LCTL> {    [ Alt_L     ]   };
key <LWIN> {    [ Super_L       ]   };
key <RTSH> {    [ Shift_R       ]   };
key <RCTL> {    [ Alt_R     ]   };
key <RWIN> {    [ Super_R       ]   };
key <MENU> {    [ Menu          ]   };
// Beginning of modifier mappings.
modifier_map Shift  { Shift_L, Shift_R };
modifier_map Lock   { Caps_Lock };
modifier_map Control{ Control_L, Control_R };
modifier_map Mod2   { Num_Lock };
modifier_map Mod4   { Super_L, Super_R };
// Fake keys for virtual<->real modifiers mapping:
key <LVL3> {    [ ISO_Level3_Shift  ]   };
key <MDSW> {    [ Mode_switch       ]   };
modifier_map Mod5   { <LVL3>, <MDSW> };
key <ALT>  {    [ NoSymbol, Control_L, Control_R    ]   };
//include "altwin(meta_alt)"
key <LALT> {    [ Control_L     ]   };
key <RALT> {    [ Control_R     ]   };
modifier_map Mod1   { Alt_L, Alt_R, Meta_L, Meta_R };
key <META> {    [ NoSymbol, Meta_L, Meta_R  ]   };
modifier_map Mod1   { <META> };
key <SUPR> {    [ NoSymbol, Super_L ]   };
modifier_map Mod4   { <SUPR> };
key <HYPR> {    [ NoSymbol, Hyper_L ]   };
modifier_map Mod4   { <HYPR> };
// End of modifier mappings.
key <OUTP> { [ XF86Display ] };
key <KITG> { [ XF86KbdLightOnOff ] };
key <KIDN> { [ XF86KbdBrightnessDown ] };
key <KIUP> { [ XF86KbdBrightnessUp ] };
hidden partial alphanumeric_keys
xkb_symbols "editing" {
key <PRSC> {
type= "PC_ALT_LEVEL2",
symbols[Group1]= [ Print, Sys_Req ]
key <SCLK> {    [  Scroll_Lock      ]   };
key <PAUS> {
type= "PC_CONTROL_LEVEL2",
symbols[Group1]= [ Pause, Break ]
key  <INS> {    [  Insert       ]   };
key <HOME> {    [  Home         ]   };
key <PGUP> {    [  Prior        ]   };
key <DELE> {    [  Delete       ]   };
key  <END> {    [  End          ]   };
key <PGDN> {    [  Next         ]   };
key   <UP> {    [  Up           ]   };
key <LEFT> {    [  Left         ]   };
key <DOWN> {    [  Down         ]   };
key <RGHT> {    [  Right        ]   };
Save.
rm -rf /var/lib/xkb/*
(I don't know if this is required, but I did it.)
Reboot.
Tom Mercer
  • 1,748
  • 20
  • 38
I was able to get this working by running the command setxkbmap -option ctrl:swap_lwin_lctl. This swaps the left control and left command keys.
