 openjdk-7-jdk : Depends: openjdk-7-jre (>= 7~u3-2.1.1~pre1-1ubuntu2) but it is not going to be installed
                 Recommends: libxt-dev but it is not going to be installed
sources
deb http://ports.ubuntu.com/ubuntu-ports/ precise main universe deb-src http://ports.ubuntu.com/ubuntu-ports/ precise main universe
Finally figured out the solution by hit and trial. In /etc/apt/sources.list replaced precise with trusty and everything works. Now am able to install the openjdk-7-jdk package.
After changing it, /etc/apt/sources.list looks like this.
deb http://ports.ubuntu.com/ubuntu-ports/ trusty main universe
deb-src http://ports.ubuntu.com/ubuntu-ports/ trusty main universe
Oli
  • 299,380
