Every time I follow the steps to use it, I click the file I downloaded and it pulls up Ubuntu Software Center with an error: Dependency not satisfiable: libglib2.0-0 (>=2.37.3). Now I thought I might have to download libglib, so I went into the command line and entered the command: sudo apt-get install libglib2.0-0 And boom, downloaded and installed. When it still didn't work I restarted, still same error message. I've tried fifteen different approaches to getting my graphics card to operate like it should in the last hour and a half just trying to circumvent this issue when I couldn't resolve it. Someone please be my hero and just tell me how to make the installer work.
Assuming you downloaded the official genuine not guaranteed to work properly graphics installer from Intel at 01.org, you first do the download, then you go to the dask and type 'intel' at which point the intel-linux-graphics-installer should appear so you can run it, or open a terminal alt+ctrl+t and enter the command
but before you do this, you should also know how to uninstall the driver should you possibly need to.
From the terminal window that you can get to by pressing alt+ctrl+f1, enter the commands
Try to completely remove your ATI drivers from your system:
sudo apt-get purge fglrx*
Remove your xorg.conf
sudo rm /etc/X11/xorg.conf
Reinstall xorg completely
sudo apt-get install --reinstall xserver-xorg-core libgl1-mesa-glx libgl1-mesa-dri
Re-configure Xorg
sudo dpkg-reconfigure xserver-xorg
Reboot
If you can't get to the terminal as described above, use the recovery mode, and enter the root mode. Use the command mount -o remount,rw / to get the disk into writeable mode, and enter the commands above.
Charles Green
  • 21,859
