I install lubuntu few days ago and I tried to add my locale(sinhala). By using command ibus-setup I got the ibus configuration window and then I add my locale. I can see the keyboard icon on the top bar and when I use key combination ctrl+space it change default English(US) to my locate. But that effects nothing. When I type all I get is English. I tried adding another locale and result is the same.
I tried running im-switch -s ibus which gives a error like
Error: no configuration file "ibus" exists.
Error: No action taken.
So I guess though ibus is running it is not set as the input method. Can anyone give me a hand here.
ravinda
  • 215
I recently had a really hard time making this work and finally solved my problem using xfce4-xkb-plugin on Lubuntu 18.04.
First install the plugin
sudo apt-get install xfce4-xkb-plugin
then right-click on the task-bar and click add/remove panel items , it will open a Panel Preferences window
Click the +Add button; it will open Add plugin to panel window select Keyboard Layout Handler and click +Add button
Now back in the Panel preferences window select Keyboard Layout Handler and click the Preferences button
This will open the Keyboard Layout Handler preferences window, whereyou need to do the following:
Under Advanced setxkbmap Options uncheck keep system layouts
Under Keyboard Layouts > +Add select the language you want to add
Under Change Layout Option choose the keys you want to toggle between the languages
Now try it يعمل جيدا معي في اللغة العربية
Zanna
  • 72,312
I think you should install the ibus-m17n package.
sudo apt-get install ibus-m17n
Then, next time you log in, you should see a bunch of new Sinhala options when running ibus-setup. Pick the one of your choice, and hopefully it makes a difference.
To add the functionality of multiple keyboards, first add (as root) to /etc/xdg/lxsession/LXDE/autostart your language choices, for example, for US and French, add
@setxkbmap -layout "us,fr".
See http://lxlinux.com/#19 for additional information.
Rex
  • 1,737
