Flash is not working on Kubuntu 11.04, 64bit on any browser. Even after a purge and reinstall, any flash application gives either says the plugin is missing or not up to date (depends on browser).
This problem is just with Kubuntu, not with Ubuntu. How can I get flash working again?
After installing the package flashplugin-installer, the command
find / -name "libflashplayer.so" doesn't find anything.
Update
December 29, 2011
Manual install is no longer necessary. The package adobe-flashplugin works as intended. If you used the script I originally provided, you'll have to do some clean up to get things working correctly again. See the now edited post for a script to do the clean up. Note that I had to completely remove and reinstall chrome to convince flash to work in chrome again.
Update
June 22,2011
I fixed it by manually installing flash.
I posted my script and made it a community wiki so it can be improved upon.
cledoux
  • 183
Updated December 29, 2011
It is no longer necessary to manually install flash. The package adobe-flashplugin will install the latest version of flash (currently 11). The original script is kept below for historical purposes.
If you used the original script to manually install flash, you'll need to do a bit of cleanup before things will work right. I've provided an additional script immediately below which will both perform the clean up and install flash.
# Clean Up #
sudo killall -9 firefox
sudo kiallall -9 chrome
# Note that it might be desirable to remove nspluginwrapper, but I have not included
# it because acroread requires it.
sudo apt-get remove -y --purge gnash gnash-common mozilla-plugin-gnash swfdec-mozilla libflashsupport adobe-flashplugin flashplugin-installer flashplugin-nonfree
sudo rm -f /usr/lib/mozilla/plugins/*flash*
sudo rm -f ~/.mozilla/plugins/*flash*
sudo rm -f /usr/lib/firefox/plugins/*flash*
sudo rm -f /usr/lib/firefox-addons/plugins/*flash*
sudo rm -rfd /usr/lib/nspluginwrapper
sudo rm -rf /usr/lib/flashplugin-manual
sudo rm -f /opt/google/chrome/plugins/libflashplayer.so
# Install #
sudo apt-get update
sudo apt-get install -y adobe-flashplugin
Note that I still had to purge chrome (sudo apt-get remove -y --purge google-chrome-stable) and redownload and install to get flash working properly in chrome. Firefox worked no problem.
Original
Adapting the script given by @anne and combining it with these instructions, I have the set of steps I followed below.
# Preparation #
sudo apt-get remove -y --purge flashplugin-nonfree gnash gnash-common mozilla-plugin-gnash swfdec-mozilla libflashsupport nspluginwrapper
# Download and Extract Flash #
cd ~
wget http://download.macromedia.com/pub/labs/flashplayer10/flashplayer10_2_p3_64bit_linux_111710.tar.gz
tar xzvf flashplayer10_2_p3_64bit_linux_111710.tar.gz
# Install #
sudo mkdir /usr/lib/flashplugin-manual
sudo mv libflashplayer.so /usr/lib/flashplugin-manual/
# Firefox
sudo ln -sf /usr/lib/flashplugin-manual/libflashplayer.so /usr/lib/mozilla/plugins/
# Note that I didn't need to do the next two commands, but I left them in anyway.
# Firefox is not my main browser, so I'm not sure what the purpose of those two commands are
sudo ln -sf /usr/lib/flashplugin-manual/libflashplayer.so /usr/lib/firefox-addons/plugins/
sudo ln -sf /usr/lib/flashplugin-manual/libflashplayer.so  /usr/lib/xulrunner-addons/plugins/
# Chrome
sudo mkdir -p /opt/google/chrome/plugins
sudo ln -sf /usr/lib/flashplugin-manual/libflashplayer.so /opt/google/chrome/plugins/libflashplayer.so
# Cleanup #
rm flashplayer10_2_p3_64bit_linux_111710.tar.gz
cledoux
  • 183
-1
I usually do it like this.
http://labs.adobe.com/downloads/flashplayer10_square.html
download and extract
#cleanup
#install
sudo cp libflashplayer.so /usr/lib/mozilla/plugins/
sudo ln -sf /usr/lib/mozilla/plugins/libflashplayer.so /usr/lib/firefox-addons/plugins/
sudo ln -sf /usr/lib/mozilla/plugins/libflashplayer.so  /usr/lib/xulrunner-addons/plugins/
Marco Ceppi
  • 48,827
-1
simpler and easier than all that stuff :S
First lets remove adobe flash, because the one that uss the repositories is the 32 bit version:
sudo apt-get remove flashplugin-installer
Now we are simply going to install the 64 bit version of the adobe flash plugin from this PPA https://launchpad.net/~sevenmachines/+archive/flash
sudo add-apt-repository ppa:sevenmachines/flash && sudo apt-get update && sudo apt-get install flashplugin64-installer
xangua
  • 7,277
