10
I've downloaded XAMPP from their website. And then manually installed it from my home directory and it is installed in /opt/lampp
I've made tons of changes and I don't remember how to revert back to it's default state, so I need a fresh new clean install.
Besides doing sudo /opt/lampp/lampp stop and sudo rm -R /opt/lampp. Is there anything else that I should delete? Maybe from files that it might used from home directory?
Apart from that. Does doing above completely remove XAMPP from my system?
AFwcxx
  • 585
6 Answers6
19
This should remove XAMPP completely as they provide the uninstaller files in /opt/lampp/
 sudo chmod +x /opt/lampp/uninstall
 sudo /opt/lampp/uninstall
Then you can make sure the unistallation is complete by doing user318149's answer above. cheers
Ravan
  • 9,567
Nurahman
  • 191
sudo /opt/lampp/lampp stop, sudo rm -rf /opt/lampp and rm -rf ~/.lampp (Log files) did it for me. There is no Lampp/Xampp related configs/logs in ~/.cache or ~/.local/share
This is the full code to uninstall lampp..
You can uninstall Xampp in ubuntu by going to terminal: Ctrl + Alt + T then type:
cd /opt/lampp
sudo ./uninstall
then you get the xampp uninstaller and you can uninstall xampp. but, there are some leftover file in the lampp folder to remove it just type in terminal:
sudo rm -r /opt/lampp
Now xampp is removed completely.
muru
  • 207,228
Dinesh
Lampp actually have an uninstaller files in /opt/lampp/named unintaller. Just change the mode using this command
  • cd /opt/lampp/ to enter the directory
  • sudo chmod +x uninstaller to change it into executable file
  • ./uninstaller to run the unistaller file
The default directory for XAMPP is “opt/lampp”.
Open the terminal and type
after this type
