How do I move and resize the xfce4-terminal by command line?
The problem is that the command echo -ne '\e[3;0;0t' does not re-position my xfce4-terminal and has no apparent affect. man xfce4-terminal and other answers suggest it should.
xfce4-terminal emulates the xterm application developed by the X Consortium. In turn, the xterm application emulates the DEC VT102 terminal and also supports the DEC VT220 escape sequences.
http://invisible-island.net/xterm/ctlseqs/ctlseqs.html
http://rtfm.etla.org/xterm/ctlseq.html
The goal is to write a script that creates a few terminals and sets up my working environment without needing to click and resize my terminals to my comfort.
What does work is echo -ne '\e[8;40;80t' which the causes the terminal to resize correctly. So why not moving the window?
Other information that I am unsure may affect anything:
I have tried other numbers such as the sequence '\e[3;100;100t' but nothing seems to relocate the terminal window.
I am actually running ubuntu and installed and launch with xfce4 after unity started having issues from an update.
xfce4-terminal 0.6.3 (Xfce 4.10)
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
fruse
  • 81
The man page for xfce4-terminal specifies using the --geometry option to set the size and placement of a terminal.
This flag uses the options "-geometry WIDTHxHEIGHT+XOFF+YOFF (where WIDTH, HEIGHT, XOFF, and YOFF are numbers) for specifying a preferred size and location for this application's main window."
Refer to the "Geometry Specifications" section of the man page for X (man X).
Here are several examples of xterm placement:
  1. Place a short and wide terminal window on upper left-hand side of the display:
    xfce4-terminal --geometry 140x20+50+50
  2. Place a square terminal window in the lower left-hand corner of the display:
    xfce4-terminal --geometry 100x40+40+500
  3. Place a square terminal window in the upper right-hand corner of the display:
    xfce4-terminal --geometry 100x40+1500+40
  4. Place a short and wide terminal window on lower right-hand side of the display:
    xfce4-terminal --geometry 140x20+1500+500
If you would like to make this setting permanent, follow these instructions:
"copy the terminal launcher (terminal's .desktop file) from /usr/share/applications/ to ~/.local/share/applications/ and edit the Exec field accordingly" as mentioned in the answer here.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
