The installation gets to the screen of Ubuntu where it's loading, I click the left button to see code and here's what it says is happening:
stdin: Not a typewriter
Generating locales...
    en_US.UTF-8... done
Generation complete.
chroot: can't execute 'glib-compile-schemas': Input/output error
chroot: can't execute '/usr/lib/user-setup/user-setup-apply': Input/output error
install: invalid user 'ubuntu'
Using CD-ROM mount point /cdrom/
Identifying... [bac8495d27ebe9f23250907977f69e73-2]
Scanning disc for index files...
Found 2 package indexes, 0 source indexes, 0 translation indexes and 1 signatures
Found label 'Ubuntu 14.04 LTS _Trusty Tahr_ - Release amd64 (20140417)'
This disc is called:
Copying package lists... gpgv: Signature made Thu Apr 17 01:35:09 2014 UTC using DSA Key ID FBB75451
gpgv: Good signature from "Ubuntu CD Image Automatic Signing Ket <cdimage@ubuntu.com>"
Reading Package Indexes... Done
Writing new source list
Source list entries for this disc are:
deb cdrom: [Ubuntu 14.04 LTS _Trusty Tahr_ - Release amd64 (20140417)]/trusty main restricted
Repeat this process for the rest of the CDS in your set...
*Starting Mount filesystem on boot                       [OK]
*Starting Signal sysvinit that the rootfs is mounted     [OK]
*Starting Populate and link to /run filesystem           [OK]
*Stopping Track if upstart is running in a container     [OK]
*Starting Mount filesystem on boot                       [fail]
*Stopping Mount filesystem on boot                       [OK]
Then there's a lot of things that happen in one second, and I couldn't write it down. It sends me to a screen that says:
General error mounting filesystems
A maintenance shell will now be started
CONTROL-D will terminate this shell and reboot the system
(Sorry if there's any mispelling, I translated it from handwriting. And by the way I'm not from USA, I don't know why it says "en_US.UTF-8... done", and the time marked in the signature seems to be also from the USA.)
Jens Erat
  • 5,131
  • 33
  • 37
By the Input/Output error, I suspect your CD/DVD reader may be failing, you should maybe try making a bootable USB drive.
JorgeArtware
  • 3,637
