i can't find how to install and use the labelwriter 450 and it's urgent. i print for my job 50 to 100 labels per week.
i don't know what to do, i just went to ubuntu from windows 8.1.1.
I tried with wine but still doesn't work.
kailor
  • 172
5 Answers5
12
14.04 and later
Open the terminal and type:
sudo apt install printer-driver-dymo
karel
  • 122,292
  • 133
  • 301
  • 332
rew
  • 424
11
To install Dymo 450 LabelWriter on Debian Systems - Ubuntu, Raspibian, you might need first: (helped me to compile drivers, advice from : http://ubuntuforums.org/showthread.php?t=1502581 )
sudo apt-get install libcups2-dev libcupsimage2-dev gcc g++
Then you want to do install dymo linux sdk (both links work at 2016-05-14):
Then you unpack it, compile and install driver:
./configure
make
sudo make install
Later I've added driver via cups web interface like any other driver, choosing right ppd file. (example project : https://www.hmazter.com/2013/05/raspberry-pi-printer-server-for-labelwriter and another: https://gist.github.com/gwpl/6d6c1457b4d1f6b778917a2f7c3c57fd ).
Finally, I share via network Dymo 450 LabelWriter(s) attached to Ubuntu and Raspibian with other Linuxes (including Archlinux) and I've found that to make printing via network (e.g. ipp:// and ipps:// ) to work, I need to schedule printing (of pdf, png, whatever) add -o raw to lpr command. You will see example of -o raw in https://gist.github.com/gwpl/6d6c1457b4d1f6b778917a2f7c3c57fd and https://askubuntu.com/a/748035/31300 .
Finally references for installing and using Dymo 450 under Linux:
You need to get the correct drivers for CUPS, the Linux printing system. As far as I can tell, you can download them here:
https://dymo.custhelp.com/app/answers/detail/a_id/101/~/dymo-drivers-and-downloads#lw_linux
The answer by Grzegorz kinda works, but there is an issue in the official DYMO sources which prevents it from building on the latest version of CUPS. I found a patch on this Ubuntu forum post which contains the fix for it.
The post's instructions were:
git clone https://aur.archlinux.org/dymo-cups-drivers.git
Then copy that files inside the folder of driver, and finally:
* patch -Np1 -i cups-ppd-header.patch
* ./configure
* make
* sudo make install
Basically, several files are missing this line, which makes it impossible to build:
#include <cups/ppd.h>
I made the change against the official version 1.4.0.5 copy of the source and put it in a repository for others to use: https://github.com/Kyle-Falconer/DYMO-SDK-for-Linux
Just FYI: If you need a label printer, do not buy a DYMO from this point in time onwards.
I have contacted their customer support and although not properly mentioned on their website, they have stopped supporting Linux as of this point in time.
rew
  • 424
