24
I have the Tor service, and I want to use the terminal to change the IP address which Tor gives me. In other words: How do I request a new IP address from Tor on the command line?
RonJohn
  • 679
Austin
  • 425
5 Answers5
27
For tor daemon running on Ubuntu, first try this:
killall -HUP tor
If that does not work, enable the control port in your torrc file.
Then, set a password for the control port with tor --hash-password password
Open a telnet connection to the control port and issue the NEWNYM command:
printf 'AUTHENTICATE "password"\r\nSIGNAL NEWNYM\r\n' | nc 127.0.0.1 9051
sources:
mchid
  • 44,904
  • 102
  • 162
24
You can simply type or insert in your bash script:
service tor reload
Method 1: HUP
Mentioned at Change IP address which is given by Tor using the terminal but here go a few more details:
sudo killall -HUP tor
Then check that your IP has changed with:
curl --socks5 127.0.0.1:9050 http://checkip.amazonaws.com/
Tested in Ubuntu 17.10 with sudo apt-get install tor version 1.6.0-5.
sudo is needed since the process is started by root by default.
What an HUP signal does exactly to the Tor daemon is documented at: https://gitweb.torproject.org/torspec.git/tree/control-spec.txt?id=03aaace9bd9459b0d4bf22a75012acf39d07bcec#n394 and is equivalent to sending some command through the command port.
Browser Bundle 5.0.5 is not affected by this, only daemon ports like the default 9050, which is not used by the TBB. For that use case see: https://tor.stackexchange.com/questions/1071/how-can-a-new-circuit-happen-without-closing-all-tabs
If you are deploying an army of Tor IPs as mentioned here you can selectively send:
kill -HUP $PID
Method 2: control port
Mentioned by kat:
(echo authenticate '""'; echo signal newnym; echo quit) | nc localhost 9051
but for that to work on Ubuntu 17.10 you must first:
  • enable the control port by uncommenting:
    ControlPort 9051
    from /etc/tor/torrc
  • Set the empty password, otherwise it gives 515 Authentication failed: Wrong length on authentication cookie.. First run:
    tor --hash-password ''
    This outputs something like:
    16:D14CC89AD7848B8C60093105E8284A2D3AB2CF3C20D95FECA0848CFAD2
    Now on /etc/tor/torrc update the line:
    HashedControlPassword 16:D14CC89AD7848B8C60093105E8284A2D3AB2CF3C20D95FECA0848CFAD2
  • Restart Tor:
    sudo service tor restart
Bonus: how to check that your IP changed
See also:
Related threads
You can set up a control port and use the python script
from stem import Signal
from stem.control import Controller
with Controller.from_port(port = 9051) as controller:
    controller.authenticate()
    controller.signal(Signal.NEWNYM)
A one-liner that makes tor use a different ip address:
systemctl show -p MainPID tor | cut -d= -f2 | xargs sudo kill -HUP
