46
pip install scrapy
Downloading/unpacking scrapy
  Downloading Scrapy-0.24.2-py2-none-any.whl (502kB): 502kB downloaded
Downloading/unpacking pyOpenSSL (from scrapy)
  Downloading pyOpenSSL-0.14.tar.gz (128kB): 128kB downloaded
  Running setup.py (path:/home/elie/.virtualenvs/stat/build/pyOpenSSL/setup.py) egg_info for package pyOpenSSL
    warning: no previously-included files matching '*.pyc' found anywhere in distribution
    no previously-included directories found matching 'doc/_build'
Requirement already satisfied (use --upgrade to upgrade): six>=1.5.2 in /home/elie/.virtualenvs/stat/lib/python2.7/site-packages (from scrapy)
Downloading/unpacking queuelib (from scrapy)
  Downloading queuelib-1.1.1.tar.gz
  Running setup.py (path:/home/elie/.virtualenvs/stat/build/queuelib/setup.py) egg_info for package queuelib
Requirement already satisfied (use --upgrade to upgrade): lxml in /home/elie/.virtualenvs/stat/lib/python2.7/site-packages (from scrapy)
Downloading/unpacking w3lib>=1.2 (from scrapy)
  Downloading w3lib-1.6.tar.gz
  Running setup.py (path:/home/elie/.virtualenvs/stat/build/w3lib/setup.py) egg_info for package w3lib
Requirement already satisfied (use --upgrade to upgrade): cssselect>=0.9 in /home/elie/.virtualenvs/stat/lib/python2.7/site-packages (from scrapy)
Downloading/unpacking Twisted>=10.0.0 (from scrapy)
  Downloading Twisted-14.0.0.tar.bz2 (4.3MB): 4.3MB downloaded
  Running setup.py (path:/home/elie/.virtualenvs/stat/build/Twisted/setup.py) egg_info for package Twisted
Downloading/unpacking cryptography>=0.2.1 (from pyOpenSSL->scrapy)
  Downloading cryptography-0.5.2.tar.gz (319kB): 319kB downloaded
  Running setup.py (path:/home/elie/.virtualenvs/stat/build/cryptography/setup.py) egg_info for package cryptography
    Package libffi was not found in the pkg-config search path.
    Perhaps you should add the directory containing `libffi.pc'
    to the PKG_CONFIG_PATH environment variable
    No package 'libffi' found
    c/_cffi_backend.c:13:17: fatal error: ffi.h: No such file or directory
     #include <ffi.h>
    compilation terminated.
    Traceback (most recent call last):
      File "<string>", line 17, in <module>
      File "/home/elie/.virtualenvs/stat/build/cryptography/setup.py", line 174, in <module>
        "test": PyTest,
      File "/usr/lib/python2.7/distutils/core.py", line 111, in setup
        _setup_distribution = dist = klass(attrs)
      File "/home/elie/.virtualenvs/stat/local/lib/python2.7/site-packages/setuptools/dist.py", line 239, in __init__
        self.fetch_build_eggs(attrs.pop('setup_requires'))
      File "/home/elie/.virtualenvs/stat/local/lib/python2.7/site-packages/setuptools/dist.py", line 263, in fetch_build_eggs
        parse_requirements(requires), installer=self.fetch_build_egg
      File "/home/elie/.virtualenvs/stat/local/lib/python2.7/site-packages/pkg_resources.py", line 564, in resolve
        dist = best[req.key] = env.best_match(req, self, installer)
      File "/home/elie/.virtualenvs/stat/local/lib/python2.7/site-packages/pkg_resources.py", line 802, in best_match
        return self.obtain(req, installer) # try and download/install
      File "/home/elie/.virtualenvs/stat/local/lib/python2.7/site-packages/pkg_resources.py", line 814, in obtain
        return installer(requirement)
      File "/home/elie/.virtualenvs/stat/local/lib/python2.7/site-packages/setuptools/dist.py", line 313, in fetch_build_egg
        return cmd.easy_install(req)
      File "/home/elie/.virtualenvs/stat/local/lib/python2.7/site-packages/setuptools/command/easy_install.py", line 593, in easy_install
        return self.install_item(spec, dist.location, tmpdir, deps)
      File "/home/elie/.virtualenvs/stat/local/lib/python2.7/site-packages/setuptools/command/easy_install.py", line 623, in install_item
        dists = self.install_eggs(spec, download, tmpdir)
      File "/home/elie/.virtualenvs/stat/local/lib/python2.7/site-packages/setuptools/command/easy_install.py", line 809, in install_eggs
        return self.build_and_install(setup_script, setup_base)
      File "/home/elie/.virtualenvs/stat/local/lib/python2.7/site-packages/setuptools/command/easy_install.py", line 1015, in build_and_install
        self.run_setup(setup_script, setup_base, args)
      File "/home/elie/.virtualenvs/stat/local/lib/python2.7/site-packages/setuptools/command/easy_install.py", line 1003, in run_setup
        raise DistutilsError("Setup script exited with %s" % (v.args[0],))
    distutils.errors.DistutilsError: Setup script exited with error: command 'x86_64-linux-gnu-gcc' failed with exit status 1
    Complete output from command python setup.py egg_info:
 #include <ffi.h>
    "test": PyTest,
Cleaning up...
Command python setup.py egg_info failed with error code 1 in /home/elie/.virtualenvs/stat/build/cryptography
Storing debug log for failure in /home/elie/.pip/pip.log
I used to install scrapy before, never had issues, what's wrong?
Lynob
  • 6,775
I got this error, too. The problem is
 #include <ffi.h>
You should do this:
sudo apt-get install libffi-dev
Martin Thoma
  • 20,535
seems
  • 936
12
From a fresh installation of 14.04, I had to install python-dev, libffi-dev, libssl-dev, libxml2-dev, and libxslt1-dev packages. Once those were installed, pip install scrapy worked fine.
sudo apt-get install python-dev libffi-dev libssl-dev libxml2-dev libxslt1-dev
pip install scrapy
Kasisnu
  • 540
romandas
  • 331
I have installed scrapy by using following two commands:
sudo apt-get install python-scrapy
check the version of scrapy by,
scrapy -V
