I recently found the following gvfs commands :
gvfs-cat (1) - Concatenate files
gvfs-copy (1) - Copy files
gvfs-info (1) - Show information about files
gvfs-ls (1) - List files
gvfs-mime (1) - Get or set mime handlers
gvfs-mkdir (1) - Create directories
gvfs-monitor-dir (1) - Monitor directories for changes
gvfs-monitor-file (1) - Monitor files for changes
gvfs-mount (1) - Mounts the locations
gvfs-move (1) - Copy files
gvfs-open (1) - Open files with the default handler
gvfs-rename (1) - Rename a file
gvfs-rm (1) - Delete files
gvfs-save (1) - Save standard input
gvfs-set-attribute (1) - Set file attributes
gvfs-trash (1) - Move files or directories to the trash
gvfs-tree (1) - List contents of directories in a tree-like format
Now, how do these differ by the common commands like cat, cp, mkdir, etc.
In other words what is the difference between the following commands respectively:
catandgvfs-catcpandgvfs-copymkdirandgvfs-mkdiretc. and so on.
or what for gvfs-* commands stands for?
