I finally installed Ubuntu 14.04 (from a boot CD) but everything seems so slow. It takes a few seconds to open a window or to close a window, like if everything was in slow motion. When I type a text in any field, specially from the launcher, the characters appear on the monitor much slower than I type them. I know I have little memory, but it is still too slow. I read about updating video drivers, but I don't know how to upgrade them as there no new "recommended" ones.
Here is what I have:
  • Memory 985.0 MiB
  • IntelĀ® Pentium(R) M processor 1.70GHz
  • Graphics VESA: Intel(r)852GM/852GME/855GM/855GME
  • 32 bit OS
  • 40G HDD The PC is a Inspiron 710m laptop.
Any advice would be appreciated, Thanks!
I think you should try using lubuntu distro you are currently using Unity Desktop which requires much higher hardware Configuration. So, in my opinion you should try installing lubuntu
You can get more details and download it here also as you have a slow system and very little space I also recommend you to download Lubuntu from other system and make a live usb from that system (usually windows system) and then install it in your system.
pendrive linux and this link will help you with installation
Chinmaya B
  • 7,022
  • 27
  • 43
The hardware specs are low, you'd be better with lubuntu or xubuntu. But you can remove fancy effects from unity as well. Browse the software center for Unity Tweak and install it. Remove transparencies, active blur from dash and so on. That may help.
Danilo
  • 127
