I was following instructions from here: http://www.drivard.com/2012/06/installation-freenx-server-ubuntu-12-04-lts-precise/
I installed FreeNX on my server (Ubuntu 14.04).
I am able to remotely ssh into the server.
Using NoMachine (which has been tested with other servers and work on the client) I was able to connect to the server BUT THE SCREEN WAS BLACK.
The process for connecting to the server is:
  • set up the connection (via ssh using the 'NoMachine login' option).
  • connect, entering password and username
  • chose 'start Gnome session'
  • Then black screen.
I have successfully managed this process at other times.
Edit:
  • resetting the server doesn't help
  • the problem persists when using different NoMachine clients
karel
  • 122,292
  • 133
  • 301
  • 332
A partial solution allows me to log in via NoMachine but I'm still unable to disconnect from a session without terminating it.
On the server I executed the following command:
sudo apt-get install xfce4
Then on the client when setting up nomachine client I selected "custom" instead of gnome session and entered the following options:
Desktop: Custom
Run the following command: /usr/bin/startxfce4
Options: New virtual desktop
I followed instructions from here on Ubuntu Forums
Zanna
  • 72,312
