I'm running Trusty Tahr (14.04) server. I've attached an iscsi disk and mounted it, mkfs, etc. works great, if I do it manually.
I'd much prefer to have my box mount the disk at boot so I've modified /etc/iscsi/iscsid.conf by removing the comment hash node.startup = automatic and commenting out node.startup = manual (note: this isn't the default, but i've tried it both ways and i'm sticking with the automatic as that makes sense)
node.startup = automatic#
# node.startup = manual
fstab looks good. i've git my block id set, _netdev is set, and as I stated earlier, manually, everything works. if I mount the disk, the fstab config leads the mount correctly.
in general use, things look good. (in fact, it's a time machine backup).
My only issue is, why isn't this working at boot? Boot.log shows this info:
* Starting iSCSI initiatior service iscsid [ OK ]
iscsiadm: No records found
* Setting up iSCSI targets * Stop
Clearly, an error is evident, but where? Aside from having to issue: sudo iscsiadm -m node --login I don't have to intervene.
Just .... need ... that ... last ... piece. thanks
