When booting I will have to boot maybe 3 or 4 times to get a screen that is not displayed diagonally or is not using the full screen width.
Hardware specification: HP s7727c with AMD64 and NVIDIA chipsets and Insignia 22" monitor/TV. The Ubuntu version is 9.10 Karmic.
I'd like to stay current with Ubuntu on this machine, but have gone down to 9.10 to get this described functioning. I tried higher versions and could not get past the "black screen" I think this issue is connected to the NVIDIA chipset/driver problem.
I am a GUI user and I don't follow the other solutions posted which make use of the command line. I suppose if the command line solution could be given without making any assumptions of the receiving person's knowledge base, then even I and others like me, could implement it.
Thank you for your time and assistance. Doug
Binarylife
  • 16,662
dsiddens
  • 101
Doug - you may be aware that 9.10 is no longer supported and you will no longer get any updates nor will be able to install up-to-date software from the repositories.
As to your black-screen issues on either the installation of 10.04 or higher, maybe my answer here should help.
Possibly your nvidia issues could be solved using my answer here
fossfreedom
  • 174,526
