This question was asked a lot in the past, but since ntpdate has been depricated, I'm having issues finding answers that work via ntp.conf. I've read a lot about setting a cron job for ntpdate is a bad idea now, so that answer won't work for me.
My server time (ubuntu 14.04 server) is drifting quite a bit, and I have a time server I'm using locally.
In my ntp.conf file I have my server listed like this
server 192.168.1.25 iburst burst minpoll 4 maxpoll 4
Despite these settings the watchdog timer run from
ntpdc -c loopinfo
never resets and my drift keeps getting larger and larger.
To sum up my question, why isn't my /etc/ntp.conf file actually doing anything? More info: This is a Ubuntu 14.04 VM running on Hypver-V and is used as a Redmine server.
output of ntpq -p (not sure if typo, but no q option)
    remote           refid        st  t  when  poll  reach   delay   offset   jitter
    myother.server 192.168.1.26    2  u   2    16    377     0.607   0.808     4691.46
Eric Carvalho
  • 55,453
After a bit of searching, the problem was obvious. It wasn't actually a problem with the machine itself, but with hyper-v. Apparently Hyper-v is a terrible choice for linux virtualization. It's a known problem that doesn't appear to have a fix other than just running something on the guest Linux machine.
I use this cron job
0 * * * * /usr/sbin/ntpdate 192.168.1.x
obviously the 192.168.1.x represents the ntp server. This fixed my time every hour. The documentation on how hyper-v has a hard time keeping time with linux guests is noted in several places such as here, and here.
