W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/raring-security/restricted/binary-i386/Packages 404 Not Found [IP: 91.189.88.153 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/raring-security/universe/binary-i386/Packages 404 Not Found [IP: 91.189.88.153 80]
- 1,002
When you run it, apt-get is not able to find the directory in the server.
With a browser you can try to follow the link http://archive.ubuntu.com/ubuntu/dists/raring-security/restricted/binary-i386/Packages and you will find an error because it doesn't exist anymore the directory.
If you rise the path you will have the first non error page in http://archive.ubuntu.com/ubuntu/dists/. From here you can see which are the distribution you can still download.
So you can edit your /etc/apt/sources.list and substitute all the repository like http://archive.ubuntu.com/ubuntu/dists/raring-security/restricted/ with
http://archive.ubuntu.com/ubuntu/dists/trusty-security/restricted/to switch to a supported one. It is the 14.04 LTS, or Trusty Tahr, supported till April 2019...http://old-releases.ubuntu.com/ubuntu/dists/raring-security/restricted/to change source to the old one.
A suggestion: dist-upgrade as you can.
If you need to remain with the old version, as suggested by diogo-melo, you can change your source list doing the replacement with the command:
sudo sed -i 's/archive.ubuntu/old-releases.ubuntu/g' /etc/apt/sources.list
I strongly recommend to do in advance a backup copy of your source.list file
sudo cp -i /etc/apt/sources.list /etc/apt/sources.list.old
It will prompt in case sources.list.old already exists and, in this case, feel you free to use another name for the backup copy.
