18
I did not notice any difference between them.
I was hoping "completely remove" will remove all hidden configuration files in the home directories, but it is not doing that.
So, what actually is the difference between them? And is it possible to remove also all configuration files when uninstalling an application?
Thanks
enzotib
  • 96,093
suli8
  • 2,975
To add a little bit to what Rinzwind and nickguletskii said, completely remove will remove configuration files in /etc directory, but never touch personal configuration files in your home folder, that can only be removed by hand.
enzotib
  • 96,093
10
The 'complete removal' option instructs Synaptic to remove any configuration files associated with the package as well.
Source: community wiki
Normal removal is equivalent to sudo apt-get remove application using terminal.
Complete removal is equivalent to sudo apt-get remove --purge application.
Files in your home folder are not part of the package so they will stay on your system until you remove them yourself.
Rinzwind
  • 309,379
Removal will remove the package. Complete removal will remove the package and also remove configurations associated with the package.
So if you remove and then install a package, your settings will still be there. If you completely remove and install a package, your settings will be kept.
However, this will only remove configurations in the /etc directory, so that no personal information gets lost. Thanks to @enzotib for the clarification!
