-1
The method below works to mount a primary partition from the disk image, but fails trying to mount a logical partition under an extended partition. Is there a way around this? I have 3 logical partitions under the extended partition and none of these will mount using the steps below.
Get the partition layout of the image
$ sudo fdisk -lu sda.img
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
  Device Boot      Start         End      Blocks   Id  System
sda.img1   *          56     6400000     3199972+   c  W95 FAT32 (LBA)
Calculate the offset from the start of the image to the partition start
Sector size * Start = (in the case) 56 * 512 = 28672
Mount it on /dev/loop0 using the offset
sudo losetup -o 28672 /dev/loop0 sda.img
Now the partition resides on /dev/loop0. You can fsck it, mount it etc
sudo fsck -fv /dev/loop0
sudo mount /dev/loop0 /mnt
Unmount
sudo umount /mnt
sudo losetup -d /dev/loop0
Here's a script I use to mount partitions from image files. See the comments at the start of the script for usage information.
#!/bin/bash
# mount_image, a program that mounts a specific partition from a RAW
# disk image file, such as a full-disk dd copy or a file used by QEMU.
# Note that compressed and other space-saving formats (qcaw2, etc.)
# will NOT work!
# Use:
# mount_image image_file partition_number mount_point
# For instance,
# mount_image image.raw 2 /mnt/shared
# mounts partition 2 from image.raw at /mnt/shared.
# This program relies on my GPT fdisk (gdisk) program to help identify
# partitions. I could have used regular fdisk, but this would have
# limited the program to working with MBR-formatted disks. With gdisk,
# both MBR- and GPT-formatted disks will work.
gdisk -l $1 > /tmp/mount_image.tmp
let StartSector=`egrep "^   $2|^  $2" /tmp/mount_image.tmp | fmt -u -s | sed -e 's/^[ \t]*//' | head -1 | cut -d " " -f 2`
let StartByte=($StartSector*512)
echo "Mounting partition $2, which begins at sector $StartSector"
mount -o loop,offset=$StartByte $1 $3
rm /tmp/mount_image.tmp
Rod Smith
  • 45,120
  • 66
  • 108
