I am trying to build a script/command that will restart our Asterisk/Elastix service on our PBX. The script is basically using simple command with auto log-in public key that run from Ubuntu 14.04LTS:
The command script is:
ssh user@iphost 'service asterisk restart'
But after the command finished and service restarted, the ssh stays and only after ctrlc its breaks out.
My question, is how can I terminate the session after the command completes?
Aaron
  • 6,764
user1289947
  • 127
5 Answers5
Try redirecting stdin, stdout, and stderr to /dev/null. For an explanation, see https://serverfault.com/questions/36419/using-ssh-to-remotely-start-a-process.
using option -t (terminal) in ssh command solves the problem too (better than redirecting stdout if command output is something usefull that we want to see):
ssh -t remoteip command
Try using "here document"
ssh user@iphos << endexe
   exit
endexe
That should work.
YoMismo
  • 101
You could just background it as soon as it runs:
ssh user@iphost 'service asterisk restart &'
I've got a similar issue with an xinit-based upstart service that hogs the stage and needs manually exiting (doesn't harm the Upstart job), but yeah, wang a & on the end and that should force it into the background.
If that gives you gyp, there are a number of other options like:
ssh user@iphost 'setsid service asterisk restart'
Oli
  • 299,380
You can use one of the following commands instead:
  • Restarts the service and then exits:
    ssh user@iphost 'service asterisk restart; exit'
  • Restarts the service and then exits on success:
    ssh root@iphost 'service asterisk restart && exit'
