According to the title that.
Solution like this one: apt-cache rdepends packagename
Does list all the reverse package. Although most of the packages in the list I do not have in my system installed. Example:
apt-cache rdepends python-gpgme
python-gpgme
Reverse Depends:
  python-bzrlib
  bzr
  python-gpgme:i386
  nautilus-dropbox
  assword
  alot
  python-gpgme-dbg
  python-bzrlib
  bzr
I do not have bzr, nautilus, alot, and others installed.
So, what is the correct command to find out the list of installed dependent package to that "target" package?
I need to know if python-gpgme is OKAY to purge.
Braiam
  • 69,112
AFwcxx
  • 585
If in doubt, just use the -s (aka --simulate, --just-print, --dry-run, --recon and --no-act) flag. You can run the command without root and it'll tell you what it would do based on your current packages.
$ apt-get remove -s python-gpgme
NOTE: This is only a simulation!
      apt-get needs root privileges for real execution.
      Keep also in mind that locking is deactivated,
      so don't depend on the relevance to the real current situation!
Reading package lists... Done
Building dependency tree
The following packages will be REMOVED
  python-gpgme
0 to upgrade, 0 to newly install, 1 to remove and 217 not to upgrade.
Remv python-gpgme [0.3-0ubuntu3]
Oli
  • 299,380
With aptitude's search patterns (verbose syntax and equivalent shorthand syntax):
aptitude search '?depends(python-gpgme) ?installed'
aptitude search '~Dpython-gpgme ~i'
To include recommendations as well as strict dependencies:
aptitude search '(?depends(python-gpgme) | ?recommends(python-gpgme)) ?installed'
aptitude search '(~Dpython-gpgmg | ~Drecommends:python-gpgme) ~i'
Or, using aptitude as Gilles answer, just use the why command that will show you "why a package was installed":
aptitude why python-gpgme
For example:
➜  ~  aptitude why python-gpgme
i   bzr Recommends python-gpgme
This tells me, that if there was a reason to install python-gpgme it would be due bzr package that it's installed.
Braiam
  • 69,112
You can also do:
sudo dpkg -s <package_name> | grep Depends
For example:
sudo dpkg -s bcmwl-kernel-source | grep Depends
Depends: dkms, linux-libc-dev, libc6-dev
chili555
  • 61,330
