I've recently change my PC OS from MS to Ubuntu.
Ubuntu 14.04 can correctly find my HDMI audio but with terrible echo and crackling sound.
I fix the echo issue by following the guide here: Sound problems in Ubuntu 14.04, and Static and crackling in my HDMI audio?. But the crackling sound still exist. I tried updating the video card driver directly from AMD website, didn't help either.
I also try to change the default sampling frequency in /etc/pulse/daemon.conf to 44100 or 48000, both won't work.
I'm using video card MSI ATI R7 260x. How can I fix it, thanks!
KKyang
  • 165
This one helped me: [Static and crackling in my HDMI audio?]: Static and crackling in my HDMI audio?
edit
/etc/pulse/default.pa
look for
load-module module-udev-detect
add tsched=0
load-module module-udev-detect tsched=0
reboot
hatek
  • 61
Found the solution here:
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1321421
Cause my PC comes with an Intel Z97/H97 chipset, the solution to solve this problem is:
  1. sudo nano /etc/modprobe.d/alsa-base.conf
  2. Add options snd-hda-intel vid=8086 pid=8ca0 snoop=0 at the end of the file.
  3. Restart PC
KKyang
  • 165
This was taken on Ubuntu website and solved it for me
HDMI Audio
The open-source radeon driver supports HDMI audio on Radeon HD 6000-series and earlier chips. On Trusty/14.04 and newer, HDMI audio should work automatically.
On release older than Trusty/14.04, users will need to to enable HDMI audio manually by passing the radeon.audio=1 kernel parameter. It can be done with the following command:
echo "options radeon audio=1" | sudo tee /etc/modprobe.d/radeon.conf
Ubuntu Precise/12.04 users should also note that they may need a newer kernel (>= 3.5.x) to enable HDMI audio on later cards
andrew.46
  • 39,359
