I've installed Ubuntu 12.04 on a Dell Inspiron 1545 and I cannot access the internet. On the menu, Wired says the cable is unplugged and Wireless cannot find any network available.
The laptop comes with a Dell Wireless 1397 WLAN MiniCard.
I did try to connect using an Ethernet cable. When I went to System Settings -> Networks there was no list of connections and at the top it said "the cable is unplugged".
I found similar questions about problems with wireless connection and one of the answers was to connect with a cable and download a driver, that's why I tried wired connection first.
I also found recommendations to use
sudo apt-get install --reinstall bcmwl-kernel-source
or
sudo apt-get purge bcmwl-kernel-source
as a first step of fixing the problem. When I typed any of these commands I got as response that the package was not found.
after running lspci | grep Network the output is:
0c:00.0 Network controller: Broadcom Corporation BCM4312 802.11/g LP-PHY (rev 01)
Below I paste the commands I ran and the output
cat /etc/lsb-release; uname -a
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=12.04
DISTRIB_CODENAME=precise
DISTRIB_DESCRIPTION="Ubuntu 12.04.3 LTS"
Linux User 3.8.0-29-generic #42~precise1-Ubuntu SMP Wed Aug 14 16:19:23 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
lspci -nnk | grep -iA2 net
0c:00.0 Network controller [0280]: Broadcom Corporation BCM4312 802.11b/g LP-PHY [14e4:4315] (rev 01)
    Subsystem: Dell Wireless 1397 WLAN Mini-Card [1028:000c]
    Kernel driver in use: b43-pci-bridge
iwconfig
lo        no wireless extensions.
lsmod
Module                  Size  Used by
nls_iso8859_1          12713  1
bnep                   18258  2
rfcomm                 47864  0
bluetooth             247024  10 bnep,rfcomm
joydev                 17613  0
parport_pc             28284  0
ppdev                  17113  0
snd_hda_codec_idt      71153  1
uvcvideo               82214  0
videobuf2_core         40785  1 uvcvideo
b43                   392109  0
videodev              130053  2 uvcvideo,videobuf2_core
videobuf2_vmalloc      13056  1 uvcvideo
videobuf2_memops       13202  1 videobuf2_vmalloc
mac80211              630977  1 b43
cfg80211              525244  2 b43,mac80211
snd_hda_intel          44339  3
snd_hda_codec         141716  2 snd_hda_codec_idt,snd_hda_intel
snd_hwdep              13668  1 snd_hda_codec
snd_pcm               102477  2 snd_hda_intel,snd_hda_codec
snd_seq_midi           13324  0
snd_rawmidi            30417  1 snd_seq_midi
coretemp               13596  0
i915                  620421  3
snd_seq_midi_event     14899  1 snd_seq_midi
snd_seq                61930  2 snd_seq_midi,snd_seq_midi_event
mac_hid                13253  0
gpio_ich               13526  0
snd_timer              29989  2 snd_pcm,snd_seq
dell_wmi               12681  0
drm_kms_helper         49597  1 i915
sparse_keymap          13890  1 dell_wmi
snd_seq_device         14497  3 snd_seq_midi,snd_rawmidi,snd_seq
psmouse                97873  0
dell_laptop            17425  0
drm                   287564  4 i915,drm_kms_helper
microcode              23017  0
dcdbas                 14449  1 dell_laptop
serio_raw              13215  0
lpc_ich                17144  0
i2c_algo_bit           13564  1 i915
snd                    69533  15 snd_hda_codec_idt,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
bcma                   41244  1 b43
video                  19652  1 i915
soundcore              12680  1 snd
snd_page_alloc         18798  2 snd_hda_intel,snd_pcm
wmi                    19256  1 dell_wmi
lp                     17799  0
parport                46562  3 parport_pc,ppdev,lp
ums_realtek            18256  0
usb_storage            61749  2 ums_realtek
ahci                   25879  2
libahci                31606  1 ahci
ssb                    57842  1 b43
Braiam
  • 69,112
linuxbegin
  • 43
sudo apt-get purge b43-fwcutter firmware-b43-installer
Download the b43updated.zip file to a usb flash drive then drag and drop the file to your ubuntu desktop. Right-click it and select Extract Here.
Open a terminal and do:
sudo mkdir /lib/firmware/b43
sudo cp Desktop/b43_updated.zip/*  /lib/firmware/b43
sudo modprobe -rv b43
sudo modprobe -v b43
if it does not come on reboot. Wireless should now be working, it looks like your ethernet card is not even detected.
Wild Man
  • 8,327
