19
I am using this script with gnome terminal:
#!/bin/sh
gnome-terminal --tab --title="1" --command="ssh 1" \
--tab --title="2" --command="ssh 2" \
--tab --title="3" --command="ssh 3" \
--tab --title="4" --command="ssh 4"
exit 0
How can I do the same things by script but on a Guake terminal?
derHugo
  • 3,376
  • 34
  • 52
TbMa
  • 535
5 Answers5
Did you read guake --help?
Usage: guake.py [options]
Options:
  -h, --help            show this help message and exit
  -t, --toggle-visibility
                        ?ndert die Sichtbarkeit des Terminal-Fensters.
  -p, --preferences     Zeigt die Einstellungen von Guake
  -a, --about           Zeigt Guake's Programminformationen
  -n NEW_TAB, --new-tab=NEW_TAB
                        Tab hinzuf?gen
  -s SELECT_TAB, --select-tab=SELECT_TAB
                        Tab ausw?hlen
  -g, --selected-tab    Return the selectd tab index.
  -e COMMAND, --execute-command=COMMAND
                        Eigenen Befehl im ausgew?hlten Tab ausf?hren
  -r RENAME_TAB, --rename-tab=RENAME_TAB
                        Gew?hlten Tab umbenennen
  -q, --quit            Sagt Guake das es verschwinden soll :o(
dAnjou
  • 2,055
It works like this: guake -n guake -e 'ssh 1' guake -r 'name_of_tab'
This will open a new tab, execute the command (ssh 1, in this case) and rename the newly created tab to "name_of_tab".
Try this:
#!/bin/sh
guake -n "whatever" -r "1" -e "ssh 1"
guake -n "whatever" -r "2" -e "ssh 2"
guake -n "whatever" -r "3" -e "ssh 3"
guake -n "whatever" -r "4" -e "ssh 4"
exit 0
(It turns out that neither guake -n "1" -e "ssh" nor guake -n "1" -s "1" -e "ssh 1" works, only renaming the tabs does the job)
pomsky
  • 70,557
#!/usr/bin/env bash
guake --rename-current-tab="tab0" --execute-command="ls" &
sleep 1 && guake --new-tab="my/path" --rename-current-tab="tab1" --execute-command="ls" &
sleep 2 && guake --new-tab="my/path" --rename-current-tab="tab2" --execute-command="ls" &
exit 0
Guake starts one process and a follow up Guake calls are sending instructions to the running process.
Therefore executing the above runs all 3 lines in one go as each one goes into background immediately (ends with &).
(1) start guake and rename default tab;
(2) 1 sec later we send command to open new tab, rename it, run command;
(3) +1 sec later send commands for 3 tab
The key here is to increase sleep after each call, otherwise commands can arrive at random timing and weird stuff will happen
Ssonic
I created my own script to achieve the same behaviour (with different commands) based on Panayiotis Orphanides answer; and here it is adapted to your needs:
#!/bin/sh
guake -n guake -e 'ssh 1' guake -r '1'
guake -n guake -e 'ssh 2' guake -r '2'
guake -n guake -e 'ssh 3' guake -r '3'
guake -n guake -e 'ssh 4' guake -r '4'
exit 0
I can't think of a better way, but I would appreciate any comments
derHugo
  • 3,376
  • 34
  • 52
vabada
  • 291
