16
I am running the following command:
sudo apt-get remove mongodb
And it's giving this output:
Reading package lists... Done
Building dependency tree
Package 'mongodb' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
But mongodb is still installed on my Ubuntu 13.04 system, so how can I uninstall it..?
Zanna
  • 72,312
Laxmi
  • 161
Try searching for installed mongo packages with dpkg :
$ sudo dpkg -l | grep mongo
The above command should output a list of packages with mongo in the name.
If files exist on the system, following an apt-get remove mongo, try and run the command again with the --purge switch, using a wildcard search for the name:
sudo apt-get remove mongodb* --purge
Andrew
  • 585
The general methodology here should work (upvoted), but more specifically the MongoDB packages for 2.6+ (assuming you installed them from the official repos) are:
  • mongodb-org (metapackage that will automatically install/remove) the four component packages below
  • mongodb-org-server
  • mongodb-org-client
  • mongodb-org-tools
  • mongodb-org-shell
Hence, if you try removing those packages you should have more success.
Adam C
  • 1,909
