Apologies if this is a basic question, I've recently taken ownership of our department's internal server so I'm having to deal with issues beyond my (very basic) knowledge.
Context
Our server is on a corporate network which requires corporate proxy authentication (e.g. enter corporate username and password). This is not an issue on the Windows machines on that network - when a web browser is opened the user is prompted to authenticate. However, when using a browser on Linux the user is not prompted to authenticate, the browser simply shows a message saying authentication is required.
Problem 1 - Internet Access would be useful
At the moment I have to walk to my desk on another floor if I need to look something up, because I cannot get Internet access from this machine since I cannot* (*do not know how to) authenticate. It would be useful to have the ability to authenticate so I can use a web browser.
Problem 2 - Packages cannot be updated
When I attempt to perform updates using sudo apt-get update or sudo apt-get install [package], there are errors which I believe are caused due to lack of authentication.
After performing sudo apt-get update, I get errors like W: Failed to fetch [link] 401 Authorization Required. (For some reason some http://us.archive.ubuntu.com trusty/ sources work correctly, and some throw the same error).
This is a major problem, as I need to be able to update packages on the server.
Steps Taken
- I have installed cntlm via
sudo apt-get install cntlm(it works from one of the few ubuntu repositories that randomly work). - I edited the configuration at
/etc/cntlm.confand added my username, the domain, and the proxy. - I started the service (
sudo /etc/init.d/cntlm start) - I tested the service (
sudo cntlm -I -M http://www.google.com/) and the response wasConfig Profile 1/4... Auth not required (HTTP code: 307) Your proxy is open, you don't need another proxy.
- I tried performing
sudo apt-get updateagain and still receive the same error message. (401 Authorization Required) - (Whoops! My mistake! I see I need to configure apt proxy settings manually...)
- I added the line
Acquire::http::Proxy "http://localhost:3128";to/etc/apt/apt.conf. - I restarted
cntlm. (sudo /etc/init.d/cntlm stop,sudo /etc/init.d/cntlm start)
- I performed
sudo apt-get update... and it hit0% [Waiting for headers] [Waiting for headers] [Waiting for headers] [Waiting f- and just stopped there. - I performed
sudo apt-get cleanbefore performingsudo apt-get update- this started working and then stopped at19% [Waiting for headers] - I performed
sudo apt-get cleanagain before performingsudo apt-get update- this started working and then stopped at0% [Waiting for headers] - I tried this a third time (
sudo apt-get clean,sudo apt-get update) and it stopped at20% [Waiting for headers]
- I researched this subsequent problem and found an answer on AskUbuntu suggesting this may be an issue with IPv6 causing ICS to halt for a while when it receives concurrent connections.
- I checked the
/etc/sysctl.conffile and discovered the IPv6 already appears to be disabled... (The linesnet.ipv6.conf.all.disable_ipv6 = 1,net.ipv6.conf.default.disable_ipv6 = 1, andnet.ipv6.conf.lo.disable_ipv6 = 1are already in the config file.) - (I'm now drawing a bit of a blank! The symptoms match the hypothesized IPv6 issue however if it is already disabled that doesn't seem to be able to be the cause)
- I performed
sudo apt-get cleanandsudo apt-get updatea fourth time (What the hell - why not?) and it hung on24% [Waiting for Headers]this time, but first it hit a bunch of repositories. A repository which used to trigger errors did not do so now (http://cran.rstudio.com trusty /) but one which used to trigger errors now triggered a different error,Received HTTP code 501 from proxy after CONNECT.
