177
I read through all the related answers, but they do not apply to Ubuntu 14.04.
I have no .gnome2 folder and no Passwords and Encryption keys item in the system settings. I tried to crawl through every possible menu, but I could not find out how to do it.
The popup usually pops out when I start Chromium.
Braiam
  • 69,112
Martin Drozdik
  • 3,344
  • 32
  • 39
7 Answers7
78
Fire up "User Accounts", set "automatic login" to "off". At startup you will be asked your user/password only once; popups like "unlock keyring" will never pester you again.
Walter
  • 884
This is for 14.04
  1. Open the password/keyring manager from settings (or run it directly - seahorse)
  2. Ensure Menu > View > By Keyring is ticked.
  3. In the sidebar, under 'passwords' create a new keyring 'Unprotected' (or re-use an existing keyring, e.g. 'Default', but NOT 'Login' because that will make everything unprotected which you probably don't want)
  4. Right-click the new keyring, and 'set as default'
  5. Right-click the new keyring and set its password as empty (only needed if you adopted an existing keyring)
  6. In the 'Login' keyring, delete the network secret for your wifi.
  7. Go to the network manager and add the network again - its secret should appear in the default keyring, which has no password.
  8. Set the default keyring back to Login.
35
About the Chrome and the keyrings
This problem occurs because Chrome wants to store usernames/passwords in the keyring (so they are encrypted). Therefore, every time you open Chrome, it tries to unlock the keyring.
Please note that, in Linux, Chrome can use different keyring types for the passwords you store in the browser:
  • Basic keyring: where Chrome stores passwords in a local SQLite database called “Login Data” ($HOME/.config/chromium/Default/Login Data). There, the passwords are unencrypted.
  • Desktop keyrings: (i.e., gnome-keyring or KWallet) where Chrome stores the passwords in the services provided by GNOME or KDE. It stores the encrypted passwords in a special database that must be unlocked before it can be used.
To disable the “unlock your keyring” popup permanently, you may (1) instruct Chrome to avoid the desktop keyrings or (2) create a desktop keyring or modify the default one using Seahorse (for GNOME) or KDE Wallet Manager (for KDE).
You may instruct Chrome to avoid the desktop keyrings and use a local database. If you do that, Chrome will not try to unlock the keyring again. However, every time you instruct Chrome to "remember a password", the password will be stored in plan-text in the your local computer. An expert user may get access to your passwords in plan-text if you use this alternative. This solution is recommended only if you do not ask Chrome to remember your passwords.
Instructing Chrome to avoid the keyring
To run Chrome without using the keyring, you may use the option --password-store=basic:
$ google-chrome --password-store=basic
Modifying the Chrome launcher (icon) to avoid the keyring
Considering that you usually run Chrome doing a doble-click on an icon, you must change the command for the icons you use to include the additional option to run chrome in this way all the time. You may edit (1) the global launcher in the /usr/share/applications/google-chrome.desktop folder or (2) the personal launcher file located in the ~/.local/share/applications/ directory.
  1. Edit the launcher file. For instance, using gedit
     sudo vi /usr/share/applications/google-chrome.desktop
  2. Modify the Exec= line to include the --password-store=basic option
     Exec=/opt/google/chrome/google-chrome  --password-store=basic (and any other option you want)
Jaime
  • 1,440
28
Just remove it's file as a charm:
rm ~/.local/share/keyrings/login.keyring
It started popping up (after every logout) ever since I logged-in with new password.
In my case possword had been changed during my medical leave and once I came back, I changed the new password to my old login password (I remember that easily). It ended.
I changed my password using:
sudo passwd vimal
gave changed password for sudo, the current login and then new password (my old password, typed twice).
Shut-down.
And it did not come again!
Just remove / turn off your online accounts when not needed. I had the same problem and I solved this by removing my online account.
Eliah Kagan
  • 119,640
I know this question is rather old, but for me the cause was WiFi networks. The configuration utility for NetworkManager (right-click on nm-applet and choose "Edit Connections...") offers two ways to save a WiFi password - one is to use a keyring and the other is to save it internally. I had switched from using a keyring to saving it internally because I preferred the convenience of the latter method, however the password was still saved in the keyring which then wanted unlocking.
micheal65536
  • 938
  • 13
