I am getting the following error while trying to install default-jre. How can I solve this issue?
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming.
default-jre : Depends: default-jre-headless (= 1:1.7-43ubuntu4) but it is not going to be installed
Depends: openjdk-7-jre (>= 7~u3-2.1) but it is not going to be installed
shaikh
  • 111
Use aptitude instead of apt,
sudo apt-get install aptitude
sudo aptitude -f install
sugab
  • 4,417
Try Code:
sudo apt-get update
to update your package list. Then Code:
sudo apt-get autoclean
to clean up any partial packages. Then Code:
sudo apt-get clean
to clean up the apt cache. Code:
sudo apt-get autoremove
will clean up any unneeded dependencies. If while doing this you can identify the broken package this code will very forcefully remove it. Code:
sudo dpkg --remove -force --force-remove-reinstreq package name
Change package name to the real name of course.
RCF
  • 2,127
