I'm fairly new to Linux, as many of you may have noticed. What I speak particularly is adding personal, user-generated functions and alias in my .bashrc file. I'm not exactly sure how bash works but according to many posts I "add it to the end of my .bashrc file." Which does not work when the command is executed through the Terminal.
For login shells, .profile in your home directory will be executed. So if you have functions defined in .bashrc, make sure the file is included in .profile as below:
if [ -n "$BASH_VERSION" ]; then
# include .bashrc if it exists
if [ -f "$HOME/.bashrc" ]; then
. "$HOME/.bashrc"
fi
fi
Also, you can issue the command below:
source ~/.bashrc
and then call your functions. This will make sure there is no problem in including any files.
Whenever you open a new terminal, all the commands in your .bashrc are carried out (the file is 'sourced'). If you add a new command to your .bashrc, you need to either open a new terminal or issue one of the following commands:
. ~/.bashrc
source ~/.bashrc
For example, you could put on a new line (each command has to be on a new line -- well, that's actually a simplification, but it's enough for an absolute beginner to be getting on with) at the end of your .bashrc something like:
alias hello='echo "Hello, $USER"'
...then, once you've either opened a new, fresh terminal window or used one of the source commands, you should be able to type hello and get a greeting back from your machine.
If you are doing all this and the functions/aliases don't work, then there's probably something wrong with the specific functions or aliases that you're using. If you suspect that's the case, feel free to ask a separate question.
As for tutorials, one I found very clear and useful when I was starting out with bash was linuxcommand.
- 4,625
