When I click on the Software Updater it just won't start and restarting the computer doesn't help either.
Doing sudo ap-get update in a terminal gives following error :
Reading package lists... Error!
E: Encountered a section with no Package: header
E: Problem with MergeList /var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_trusty-security_main_i18n_Translation-en
E: The package lists or status file could not be parsed or opened.
muddassir@Nexus:~$ Traceback (most recent call last):
File "/usr/share/appgrid/appdata.py", line 229, in <module>
rebuild_db()
File "/usr/share/appgrid/appdata.py", line 119, in rebuild_db
from appdata.apps.aptapp import AptApp, all_apt_pkgnames
File "/usr/share/appgrid/appdata/apps/aptapp.py", line 10, in <module>
cache = Cache()
File "/usr/lib/python3/dist-packages/apt/cache.py", line 107, in __init__
self.open(progress)
File "/usr/lib/python3/dist-packages/apt/cache.py", line 151, in open
self._cache = apt_pkg.Cache(progress)
SystemError: E:Encountered a section with no Package: header, E:Problem with MergeList /var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_trusty-security_main_i18n_Translation-en, E:The package lists or status file could not be parsed or opened.
And using sudo update-manager, gives the same error as above.
