When I'm running sudo apt-get update I am getting following errors/exceptions. Give me some solutions..
W: Failed to fetch http://mirror.kavalinux.com/ubuntu/dists/trusty/multiverse/source/Sources  404  Not Found
W: Failed to fetch http://mirror.kavalinux.com/ubuntu/dists/trusty-updates/main/source/Sources  404  Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
Mitch
  • 109,787
Is it a desktop or server edition? If desktop, try the following:
  • open System settings and click Software & Updates;
  • click the "Download from" field and select "Main server";
  • launch Software updater (or run sudo apt-get update, then sudo apt-get upgrade)
user300458
  • 2,138
