I followed everything correctly but when executing the last command I get this error
grub-install: error: cannot find EFI directory.
So far I have followed these steps
  1. Format your USB drive as NTFS using GParted
  2. Copy all files from Windows ISO to USB drive using your favorite file manager
  3. Install GRUB on USB: sudo grub-install --root-directory="/media/" /dev/sdX
I ran the command like this
sudo grub-install --root-directory=/media/christian/45A1483D795F007F/dev/sdb
Note: The drive I am running is slowly failing. A file could be corrupted! Please don't just assume this is the problem though.
Ugg I am totally stuck on this!
Thanks
UPDATE
I was doing something wrong! After /media/drive I put /dev/sdb without a space! After putting a space I now get this error
grub-install: error: /media/christian/Windows 7/ doesn't look like an EFI partition.
  1. Avoid at all costs file paths that contain spaces. So give your USB a label without spaces!
  2. The root-directory value is incorrect. You must specify the USB mount path, not its UUID.
  3. Read this again and don't forget the target argument.
Cornelius
  • 9,653
