While looking for security implications running Wine I encountered following analysis. I believe, it will serve all users interested in this topic.
Analysis from 2018 (emphasis by me):
| Malware family |
File system |
Registry |
Processes |
Network |
Services success |
Overall success |
| Narilam |
True |
True |
True |
N/A |
N/A |
True |
| Hikit |
False |
False |
False |
False |
False |
False |
| Stabuniq |
N/A |
N/A |
False |
False |
False |
False |
| Drixed |
False |
False |
False |
False |
False |
False |
| Batch Wiper |
False |
True |
False |
N/A |
N/A |
Partially |
| Dialer |
False |
False |
True |
N/A |
N/A |
False |
| MyDoom |
False |
False |
True |
False |
False |
False |
| Minamps |
True |
False |
True |
True |
False |
Partially |
| PlugX, Korplug |
False |
False |
True |
False |
N/A |
False |
| Wykcores |
True |
True |
True |
True |
True |
True |
| Didrex |
False |
False |
False |
False |
False |
False |
| Dozmot |
False |
N/A |
False |
N/A |
N/A |
False |
| Potao |
False |
N/A |
True |
N/A |
N/A |
False |
| Gamarue |
False |
True |
False |
False |
N/A |
Partially |
| TDL/Alureon |
False |
N/A |
False |
False |
N/A |
False |
| SC-KeyLog |
True |
True |
True |
True |
N/A |
True |
| Wirenet |
True |
N/A |
True |
True |
N/A |
True |
| CoreBot |
False |
False |
False |
False |
N/A |
False |
| Kawpfuni |
True |
False |
True |
N/A |
N/A |
Partially |
| Skypii |
False |
N/A |
False |
N/A |
N/A |
False |
| 4DW4R3 |
True |
N/A |
True |
False |
N/A |
Partially |
| LokiBot |
False |
False |
False |
N/A |
N/A |
False |
| Nitol |
True |
True |
True |
True |
True |
True |
| Nivdort |
False |
False |
False |
False |
False |
False |
| Unknown1 |
False |
False |
True |
N/A |
N/A |
False |
| Unknown2 |
False |
False |
False |
N/A |
N/A |
False |
| Unknown3 |
False |
False |
False |
False |
N/A |
False |
| Unknown4 |
True |
False |
False |
False |
N/A |
Partially |
| Unknown5 |
False |
False |
False |
False |
False |
False |
CONCLUSIONS
The research conducted in this study produced a series of results that can be used to develop an understanding of the behavior of Windows malware running in Linux via Wine. Results indicate that Windows malware is able to run successfully in a Linux environment through Wine. The success rates of Windows malware running in a Linux environment does appear to be relatively low. The fact that some samples of malware did run successfully illustrates that using the compatibility layer software Wine in a Linux environment does present a security risk to Linux systems, which would otherwise be secure against Windows malware. No relationships could be established between any types of malware or behavior of malware and the malware running successfully in the Linux environment; relationships between the services started in Windows and Network started in Windows independent variables may be investigated via future research and an increased sample size.
The findings suggest that samples which use particular API calls are less likely to run successfully. The OpenServiceA and OpenServiceW functions were never called in Zero Wine suggesting that using these calls can cause compatibility issues with Wine. Another possible reason for this could be that the services being opened are not available through Wine.
Source: https://link.springer.com/article/10.1007/s11416-018-0319-9
