15
I updated from OpenJDK 7 to 8. I uninstalled 7, which uninstalled the IcedTea plugin as well. I tried to reinstall IcedTea with
   sudo apt-get install icedtea-7-plugin
But it doesn't work. When I try to launch topcoder jnlp file, it fails. Also, it doesn't load any java plugin in Google Chrome. It was fine with OpenJDK 7. Is there a newer version of IcedTea for OpenJDK 8?
At the moment, icedtea-8-plugin is not available in the official Ubuntu repositories. Maarten Fonville offers a PPA repository with a working icedtea-8-plugin package.
sudo add-apt-repository ppa:maarten-fonville/ppa
sudo apt-get update
sudo apt-get install icedtea-8-plugin
Bug report: https://bugs.launchpad.net/ubuntu/+source/icedtea-web/+bug/1385842
PPA page: https://launchpad.net/~maarten-fonville/+archive/ubuntu/
If you're using Ubuntu 14.04 (for which openjdk-8-jre is not yet backported), then for the time being the OpenJDK ppa must be added first:
sudo apt-add-repository ppa:openjdk-r/ppa
Recent versions of Chrome do not support the Java plugin (cf. How do I get Java plugin working on Google Chrome?).
jthetzel
  • 295
The file you want to install is icedtea-plugin. Just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the command(s) below:
sudo apt-get install icedtea-plugin
Mitch
  • 109,787
When you are not sure what's the exact name of package like icedtea-7-plugin or icedtea-8-plugin, etc. Do a package name wise search before installing, for example search for "icedtea" word as follows:
$ sudo apt-get update
$ apt-cache search icedtea
This will display the matching package with word "icedtea" as follows:
icedtea-8-plugin - web browser plugin based on OpenJDK and IcedTea to execute Java applets
icedtea-netx - NetX - implementation of the Java Network Launching Protocol (JNLP)
icedtea-netx-common - NetX - implementation of the Java Network Launching Protocol (JNLP)
icedtea-plugin - web browser plugin to execute Java applets (dependency package)
By this you can decide which one to install..!
With the above output, use:
$ sudo apt-get install icedtea-8-plugin
The prior searching of package name will be helpful for any packages you need to install. If you are having back port issue, for the case of Ubuntu 14.04, then you may refer answer from @jthetzel.
Mithun B
  • 151
