I have tried various recommendations from the web to no success. The apt-get update gives errors . Here are my error messages after sudo apt-get udpate:
W: Failed to fetch http://ppa.launchpad.net/upubuntu-com/java/ubuntu/dists/trusty/main/binary-amd64/Packages  404  Not Found
W: Failed to fetch http://ppa.launchpad.net/upubuntu-com/java/ubuntu/dists/trusty/main/binary-i386/Packages  404  Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.
I have reviewed and tried the existing stackexchange answers that are not working for me. Trying to cleanup the ppa as per advice in sourcse gives me the following errors : For example, the following command to remove the ppa shows other scary messages :
winsella@winsella:~$ sudo rm /etc/apt/sources.list.d/ppaname-ppa-$(lsb_release -sc).list*
[sudo] password for winsella:
no talloc stackframe at ../source3/param/loadparm.c:4864, leaking memory
Failed to open /var/lib/samba/private/secrets.tdb
tdbsam_open: Failed to open/create TDB passwd [/var/lib/samba/private/passdb.tdb]
tdbsam_getsampwnam: failed to open /var/lib/samba/private/passdb.tdb!
tdbsam_new_rid: failed to open /var/lib/samba/private/passdb.tdb!
rm: cannot remove ‘/etc/apt/sources.list.d/ppaname-ppa-trusty.list*’: No such file or directory
Mateo
  • 8,152
You're looking specifically for the Oracle 7 java? If so, you may have better luck with the answer given by @user283885. Webupd8 also has an Oracle 8 java installer at this link.
If however, you just want easy to maintain, java runtimes, you should consider removing the PPS from software sources, and using the Ubuntu Software Center to load OpenJDK, either in version 6 or version 7
Charles Green
  • 21,859
