I am running 12.04 on a Toshiba Portege laptop. The graphics card is an Intel 945GM/GMS. The 2nd monitor is an Asus (Ancor Communications 22"). When I connect the monitor to the computer the monitor is recognized but nothing is displayed. There is only a black screen. The monitor is not receiving any signal from the computer.
I've had this issue for a long time and tried allot of tinkering in the terminal and nothing helped me.
What ended up helping me was, turning on the laptop with the screen connected via HDMI, and then removing the monitor from the power, and plugging it in again.
Hopefully this helps more people.
I'm using Ubuntu 20.04 and a Samsung S22D300.
- 51
Actual for ubuntu 18 and 20:
Try to (independently or together):
- adjust screen resolution for not-primary monitor
- adjust screen refresh rate (decreasing for 2nd monitor helped)
- if you have nvidia graphics choose nvidia driver in 'Software & Updates'. this may cause strange result after rebooting. i had to choose built-in monitor as primary to solve it
Updating this question.
In later versions of Ubuntu, for example >14, I think we should first check displays as previously discussed, but if that doesn't work out, to check drivers and graphics hardware of our devices. I have run into multiple monitor problems many times, but most of the time it's just a driver mismatch issue. For example, as of late I ran into a similar problem with multiple monitors being unrecognized upgrading from Ubuntu 17.10 to the latest 18.04.
In general, I would recommend:
- Upgrade Ubuntu, as 14, 16.04, and 18.04 are awesome.
- Check if you use Nvidia graphics or other, as Nvidia graphics usually works best with their own drivers in Ubuntu. If other, I have used the xorg noveau driver. You can find drivers and auto install by clicking
Ubuntu 16.04-18.04 show applications > Software and Updates > Additional Drivers
We just don't want to make things more complicated than they need to be, and manually writing xorg.conf could get complicated very quickly.
- 211
Turn off Secure Boot as indicated here https://wiki.ubuntu.com/UEFI/SecureBoot/DKMS. This solution also solves the problems with VirtualBox in Ubuntu.
Work for me Ubuntu 20.04:
- ubuntu-drivers devices
- sudo ubuntu-drivers autoinstall
try going into 'Setting -> Display' and select the Asus monitor.
Edit:
After more research I believe this is related to a bug with Intels 945GM chipset.
I also found one post that said they were able to get the monitor to work by:
- disabling the 'visual effects'
- System > Appearance > Visual Effects is set to None
- connecting monitor
- Settings -> Display
- clicking 'detect monitor'
