i have a big error warning in my Ubuntu 14 because of Spotify.
This the error :
E: Encountered a section with no Package: header
E: Problem with MergeList /var/lib/apt/lists/repository.spotify.com_dists_stable_non-free_i18n_Translation-en%5fUS
E: The package lists or status file could not be parsed or opened.
E: _cache->open() failed, please report.
I want to uninstall this program, how to do it ?
Braiam
  • 69,112
5 Answers5
27
Use this command for uninstall spotify-client :
sudo apt-get purge spotify-client
teal33t
  • 995
This won't be solved by uninstalling Spotify, only by removing the Spotify apt repository from your list of apt repositories.
Editing /etc/apt/sources.list or possibly some file in /etc/apt/source.list.d/ like fhuertas suggests will work.
If you don't want to edit files, you can start Software & Updates, go to the tab Other Software and uncheck http://repository.spotify.com stable non-free
This is both a problem with the Spotify repository and apt itself.
  • The repository is clearly broken. If you look at the file mentioned being broken, you see it contains HTML.
  • It is bad of apt to die like this, preventing even critical security upgrades from installing, because of a bad third party repository is broken.
I work at Spotify. We suck! We will fix.
jooon
  • 271
These terminal commands should solve your problem:
First remove the Merge List by opening a terminal (Press Ctrl+Alt+T to launch) and run this command:
sudo rm /var/lib/apt/lists/* -vf
Next, generate a new one by running a simple update:
sudo apt-get update
Now you should be able to run
sudo apt-get remove --purge spotify-client
Charles Green
  • 21,859
If the problem persists after Charles Green's solution, You must remove the repository from the places that you have set it.
Im my case, I had the repository en the file: /etc/apt/sources.list and I have removed it adding the # in the line symbol before the line deb http://repository.spotify.com stable non-free
 # deb http://repository.spotify.com stable non-free
The repository can be in the /etc/apt/source.list.d/ directory, you must search for a spotify file and remove it
After then update and upgrade the with apt-get tools
fhuertas
  • 141
I had the same issue and I found the solution at the Spotify forum. Credits to webrunner1981.
Here are the steps:
  1. Go to software sources (search software & updates) and find the spotify line
  2. Modify the url to http://repository-origin.spotify.com stable non-free for (source code) as well. Add the -origin in the url.
  3. In terminal then run the following commands:
    and now you can perform the update and everything should be working.
    sudo apt-get update
This should fix everything, so you don't have to uninstall. Good luck.
Lento
