Possible Duplicate:
Workspace specific wallpapers with Compiz?
Am running 10.10 and want to have a clean workspace, but also one that might be cluttered (e.g lots of launchers, documents, etc...)... is there a way to do this (am running Compiz)
Kendor
  • 4,928
I don't think there is any way to have different desktops on different workspaces for a simple reason: there is only one folder ~/Desktop (and no other structure of desktops is currently implemented).
P.S. Even having 4 different backgrounds requires some limitations: you won't be able to see any launchers on the desktop (I currently have this configuration, but I do not use desktop launchers anyway).
There is a standard way of doing this (I guess you know that, but just in case):
  • Make sure you have compiz-fusion-plugins-extra and ccsm (CompizConfig) installed
  • In CompizConfig find plugin Wallpaper, select wallpapers and check the plugin itself (enable it)
  • In the Configuration Editor (gconf-editor) uncheck apps>nautlius>preferences>show desktop
This works for both Compiz Cube and Desktop Wall but in both cases you won't see anything besides different wallpapers (no icons, no launchers, no documents etc.)
Vadim
  • 1,388
I don't see Wallpaper plugin in my CompizConfig so I found a different program that did the trick
Download Wallpapouz
