43
There was a lot of discussion about the init system for 14.04 before it was released, but I cannot find any site that explains the outcome finally.
So is Ubuntu 14.04 using systemd now?
Zanna
  • 72,312
rubo77
  • 34,024
  • 52
  • 172
  • 299
Ubuntu 14.04 uses Upstart as the init system, the plan to switch to systemd is planned for 14.10+. There are parts of "systemd" that have been used in Ubuntu for a long time, but for most intents and purposes when people say "systemd" they mean systemd-as-init.
Here's some background info:
Jorge Castro
  • 73,717
14
To show what init process is enabled:
# readlink /sbin/init
By default on 14.04 and 14.10 it's "upstart"
Changing this would involve alot more configuration than just changing this symlink so don't do that. This file is nearly always a simlink. In this case the link path does not start with / so this is a path relative to the symlink file to /sbin/upstart.
To confuse matters systemd is installed for other things but not used as init. It is in /bin not /sbin. But systemd has installed itself as init in man / help, so:
# man init
Brings up docs on systemd (as of Dec 22, 2014) This is very confusing ! You want:
# man upstart
This will give you the docs for init as they should be.
Good luck getting started. (pun ah ah)
user.dz
  • 49,176
John Hall
  • 284
If you are running Ubuntu vivid (15.04) upstart is still default, but, you can easily switch between upstart and systemd at will, since both packages are installed at present:
https://wiki.ubuntu.com/SystemdForUpstartUsers
In ubuntu 15.10 systemd is the default, but you still can choose upstart each boottime in the grub menu
rubo77
  • 34,024
  • 52
  • 172
  • 299
