On Ubuntu 14.04 I tried to dim the screen brightness to 50% on each system start in /etc/rc.local with the line
xbacklight -set 50%
right before the line exit 0
Why does this not work?
Is there a better solution?
rubo77
  • 34,024
  • 52
  • 172
  • 299
You cannot call xbacklight in rc.local, because rc.local is not running in the X environment.
Add this command to your startup programs (gnome-session-properties):
xbacklight -set 50%
This will work
rubo77
  • 34,024
  • 52
  • 172
  • 299
I use the following command to set my Surface Pro 3's brightness to 50%
xrandr --output eDP-1 --brightness 0.5
There are probably more direct ways to find your output names, but...
I installed and ran arandr. After positioning my displays how I wanted them I saved a layout (they'll show up in ~/.screenlayout/yourLayout.sh)
Then I modified that file to add the --brigtness flag, and configured the script to run at startup.
