16
I am trying to install VirtualBox on my Ubuntu.
I first tried to sudo apt-get install virtualbox-ose in a terminal, but after the configuration step, it fails with an error:
No suitable module for running kernel found When proceeding with starting virtualbox, I get this error: WARNING: The character device /dev/vboxdrv does not exist. Please install the virtualbox-ose-dkms package and the appropriate headers, most likely linux-headers-generic.
You will not be able to start VMs until this problem is fixed.
So I tried the package from http://www.virtualbox.org/, but starting VirtualBox fails with:
WARNING: The vboxdrv kernel module is not loaded. Either there is no module available for the current kernel (2.6.38-8-generic-pae) or it failed to load. Please recompile the kernel module and install it by
  sudo /etc/init.d/vboxdrv setup
So I ran sudo /etc/init.d/vboxdrv setup, but it fails too:
* Stopping VirtualBox kernel modules                                                           [ OK ]
* Uninstalling old VirtualBox DKMS kernel modules                                                            [ OK ]
* Trying to register the VirtualBox kernel modules using DKMS
Error! Your kernel headers for kernel 2.6.38-8-generic-pae cannot be found at
/lib/modules/2.6.38-8-generic-pae/build or /lib/modules/2.6.38-8-generic-pae/source.
* Failed, trying without DKMS
* Recompiling VirtualBox kernel modules
* Look at /var/log/vbox-install.log to find out what went wrong
The contents of /var/log/vbox-install.log.
As I am stuck, I also tried to install kernel-devel with yum, still fruitless:
root@ubuntu# yum install kernel-devel
Setting up Install Process
No package kernel-devel available.
Nothing to do
Now I've no idea how to correct this. Any ideas?
SoftTimur
  • 3,089
Doing everything as root by using su and the yum package manager is something that fits for Redhat-based distros, but not Ubuntu. In Ubuntu, you run command as root by prefixing commands with sudo. The package manager used by Ubuntu is apt.
To install VirtualBox, run:
This will take care of dependencies like the kernel headers which is included in the package linux-headers-generic. If you've a PAE kernel, you need to install the headers first (in your case linux-headers-2.6.38-8-generic-pae), which can be done with:
sudo apt-get install linux-headers-$(uname -r)
uname -r gives the loaded kernel version and saved you from manually entering the kernel version.
Lekensteyn
  • 178,446
I was having the same issue. I had the linux-headers-<version>-generic-pae installed but was ironically missing the linux-headers-generic-pae. If you install those that should help maybe.
Good luck!
Lekensteyn
  • 178,446
Install build-essentials.
apt-get install build-essentials
and install linux-kernel-headers
apt-get install linux-kernel-headers
or
apt-get install linux-kernel-*
Install dkms
apt-get install dkms
Octavian Helm
  • 14,515
