I have just installed Linux / Ubuntu for the first time in order to learn, and to get some experience with LAMP servers.
I also installed phpMyAdmin and used an .htaccess file (stored in /usr/share/phpMyAdmin, iirc) which points to an .htpasswd file in /etc/phpMyAdmin.
Is this considered "enough" to protect phpMyAdmin from other intruders? Is there any way someone could interact with any part of phpMyAdmin without first authenticating themselves via that .htaccess username/password?
Securing phpMyAdmin with .htaccess is considered sufficient if you're just using Ubuntu in order to learn and get experience with LAMP servers.
However, if you were working in a corporate environment, I would suggest setting up SSL Certifications with phpMyAdmin for that extra level of security.
Ben
  • 1,476
If people are accessing phpmyadmin over the Internet, you should use SSL encryption for the web traffic.
If not, add a couple lines to your htaccess file that only allows connection from the LAN.
Something like the following
Order Deny,Allow
    Deny from All
    Allow from 10.253.0.1/24
Dan
  • 6,784
